KZ1000 rear hub and disk brakes help please
- sled
08 Aug 2012 21:10
Gday
I am having trouble getting a 77-78 kz1000 (z1000 rear hub) for my GS1100 swingarm swap. I cannot locate one over here at all
I am wanting to put a 160 tyre in the GS swingarm and use a disk hub on my 76 KZ900, think there will be clearence issues if i use the drum. Anyway not many guys in the states will ship to Sydney, Australia. I see a few hubs from early 80s model KZs on fleabay are these the same??? I don't think they are they look like they are for a mag wheel. Are there any other wire spoke model disk hubs i could consider.
If anyone has one and is willing to sell it please let me know.
cheers Jason
cheers Jason
- sled
Re: KZ1000 rear hub and disk brakes help please
08 Aug 2012 21:11
No eBay APP ID and/or Cert ID defined in Kunena configurationFor example is this the same hub????
thanks guys
thanks guys
- 4TheKZ1000
08 Aug 2012 23:08 - 08 Aug 2012 23:14
I have a 3.50 X 18 (disk)not drum spoked rim on mine. the tire is a 150 70 18. The chain clears the tire by a 1/4 inch or less in 100% stock trim.
A 160 will cause problems for sure, but they could be addressed...so be aware if you go down that road. I would say that the chain will be impeded by the tire sidewall....you will need to space the sprocket and or run a front counter shaft extended sprocket. Some pics of my tire rim combo.
Last edit: 08 Aug 2012 23:14 by 4TheKZ1000.
- 4TheKZ1000
08 Aug 2012 23:10 - 08 Aug 2012 23:12
Good Luck Mate...have a Fosters on me...sort of
Last edit: 08 Aug 2012 23:12 by 4TheKZ1000.
- sled
09 Aug 2012 23:254TheKZ1000 wrote: Good Luck Mate...have a Fosters on me...sort of
Haha funny enough im more of a Beam and Makers Mark fan :evil:
