Seat Key Lock
  • Jim Parker
  • Jim Parker's Avatar Topic Author
Seat Key Lock
12 Jun 2006 22:07
#54134
The ignition key on my 78 KZ200 won't open the seat lock. I just got the bike and need access to the electrical under the seat. There is a stamp "G15" on the lock. Any assistance would be much appreciated.
Regards,
Jim
  • Mark Wing
  • Mark Wing's Avatar
Re: Seat Key Lock
12 Jun 2006 23:13
#54139
Welcome to the site. That # should be the key number for the lock. Check with the nearest Kawi dealer.
Mark
Yorba Linda Cal.
  • hydrolazer
  • hydrolazer's Avatar
Re: Seat Key Lock
13 Jun 2006 19:39
#54354
try a little lube on the lock,check tp make sure the key isnt bent some and wiggle and jiggle,,,good luck
\'79 kaw 1000 ltd
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Seat Key Lock
14 Jun 2006 06:55
#54430
Welcome.
G15 is the key #. If you can post a picture of your Ignition key, I can tell you if it's also a G15. I am a Locksmith, and can compare your key with the pic in the computer progarm. Lubing the lock with a penetrating oil is a good idea.
A Locksmith, Dealer or there are on-line places to order keys can help you if you need a key made for the lock. Or I can send you one if you can't find snything closer.
Post a pic of the bike as well.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
