Clubman bars on 82 kz650 csr
- Badkins
03 Aug 2012 15:42
I have just recently bought a 1982 kz650 csr and im in the process of putting clubman bars on, but i ran into issues with the brake fluid box hitting the gauges and headlight. Is there a way i can get these bars to work? I have thought about filing off the tiny metal petrusions under the throttle box so i no longer need a hole in the bar and just sliding the throttle off the bar maybe 1/4" but im not sure if that will effect function.
Any ideas?
Any ideas?
- damarble
Re: Clubman bars on 82 kz650 csr
03 Aug 2012 16:16
If you only need a 1/4" drill a new hole further out. The housing can rotate without the pin.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
- rstnick
04 Aug 2012 21:59 - 04 Aug 2012 22:00
Welcome Badkins.
Moving the throttle and switch housing down the bar an inch or so should be fine.
I hacked the nib off my controls in the '80s.
If the switches start to rotate, I tighten the mounting screws.
With lowered guages:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 04 Aug 2012 22:00 by rstnick.
