advice needed
- vondikka
advice needed
03 Aug 2012 15:17
78 kz650c2. i want to remove my front wheel, paint it, and replace the tire, BUT i'm not sure how to go about it. What can i do to keep the front end up? i dont have a motorcycle jack or anything, just a automobile jack. How can ihold the front end up without causing any damage to the exhaust or frame?
78 KZ650 C2
76 kz400 D3
76 kz400 D3
- StreetfighterKz
Re: advice needed
03 Aug 2012 15:27
What I have done in the past, and it's not ideal but it works. If you have a normal automotive hydraulic floor jack, take and place the "pad" underneath the lower middle engine mount on the right side of the frame. Slowly raise the jack. The front end will start to rise as the bike starts to lean onto the kickstand. I've used this method to do a frontend swap but it's definitely not ideal.
Or for a $25 you can get this stand from Harbor Freight. With the stand the bike remains balanced and perfectly upright and most importantly..stable. Then you can place a block of wood under the oil pan/exhaust and lift up the front using your jack.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- damarble
Re: advice needed
03 Aug 2012 15:35
I loop a ratchet strap around the headstock and run it up to the rafters in my garage.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
- gd4now
- Denco where did you go?
Re: advice needed
03 Aug 2012 15:55
If you have a couple of jack stands you can use them and a block of wood below the frame/engine to hold the front end up.
I have made myself an open ended wooden box of sorts out of 2 X 6s that I use. I do have to pull the exhaust (4 into 1) but then the frame rails sit on the box - does not touch the engine cases or sump at all, and it gets both front and back wheels up. I do have to pick up the front of the bike to set it on the box - having a 20 something son helps my old back with this.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Re: advice needed
03 Aug 2012 16:41
Center stands are available --
motors.shop.ebay.com/eBay-Motors-/6000/i...85.m570.l1313&_rdc=1
Re: advice needed
03 Aug 2012 17:56
You can use a small bottle jack (they're cheap) with a piece of plywood between the jack and the oil pan like so....
Attachment ForkOff.jpg not found
- faffi
Re: advice needed
03 Aug 2012 19:40
I do as Ed if I have a centre stand. If not, I put the bike on the sidestand as upright a possible - in other words, put something under the stand - and then jack near the front of the frame on the opposite side. Not ideal, but I've done it more than once.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
1980 F1 engine
B1 Points ignition
