82 KZ - steel lines all around?
- repsolracer22
02 Aug 2012 17:02
Got an 82 KZ1000 LTD. Interested in putting on steel braided lines for the brakes and replacing the clutch cable at the same time. Wondering if anyone has a nice kit out there with all of these cables in them, or if I have to order individually ...
any help would be greatly appreciated
- pete greek1
Re: 82 KZ - steel lines all around?
02 Aug 2012 17:48
I would try calling your local hose & equipment place & find out if they make steel braided brake line hoses, with banjo bolt fittings, they can probably do it cheaper than buying them on line, & they can probably make them up for right there on the spot if you bring your old hoses in with you so they have the exact measurments & banjo fitting bends...Pete
- mark1122
- Keep twisting it
02 Aug 2012 19:33
Just Call Z1E. they have Russel lines that r great at a reasonable price. if u talk to them on the phone it will be way easier, since they know these bikes very well.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- MFolks
02 Aug 2012 20:33
If you've never replaced a clutch cable, here's a procedure:
Clutch Cable Replacement On Some Kawasaki Motorcycles,with Proper Mechanism Adjustments
1.About mid way down the clutch cable is an adjuster; shorten the cable as much as possible.
2.Remove the small cover on the left side of the sprocket cover and loosen up the lock nut on the clutch throw out mechanism.
3.Remove the shifter lever; the sprocket cover, and lay the cover on some rags or news papers.
4.Have on hand a small cotter pin that will be needed to prevent the new clutch cable from coming out of the throw out mechanism.
5.At the left handlebar turn in the slack adjusters for the clutch cable and then take out the pivot bolt.
6.New clutch cables may or may not have lubrication; now's the time to either hang the new cable up overnight so heavy oil can flow through it or buy a cable luber kit with the special clamp and can of spray lube.
7.Attach the cable to the cover's throw out mechanism and secure it with a new cotter pin.
8. While you're in there, check the wiring from the alternator(YELLOW WIRES, or any wires from the alternator), remove the excess chain lube from the clutch push rod and check the wire routing that goes above the engine sprocket.
9. Check the lock washer for cracks on the engine sprocket and any "Hooking" of the sprocket teeth.
10 Route the clutch cable the same way the old one was and connect the cable to the clutch lever; and the pivot bolt gets re-installed.
11.Carefully install the sprocket cover, making sure the push rod is engaged (in the adjustment mechanism)and then tighten up the cover.
12.Adjusting the clutch play and cable tension is real easy; using a flat bladed screwdriver, turn the slotted screw clockwise(to the right) until it becomes hard to turn; then turn it counterclockwise(to the left) 1/4 turn and tighten the lock nut. On some Kawasaki’s, the adjustment will turn the opposite way, so keep this in mind.
13.The mid way cable adjuster and lever slack adjuster may need to be adjusted for correct cable slack.
14.My factory shop manual lists 2-3mm as the correct play in the lever after the cable has been properly tensioned.
15.Re-install the covers, and shifter lever, start the engine to check the shifting action.
16.These engines have a shifting lock out to prevent moving in any gear higher than second unless the engine is running and proper shifting is done.
- Motor Head
02 Aug 2012 23:14 - 02 Aug 2012 23:16
No eBay APP ID and/or Cert ID defined in Kunena configurationI bought one of these kits for the lines.
Just a couple of issues:
1- No long banjo for the double line connection at the splitter on the front.
2- The rear, and front Master lines were about 1 1/2 or so longer. Which still fit though.
Last edit: 02 Aug 2012 23:16 by Motor Head.
- repsolracer22
07 Aug 2012 12:27
well i have a hook up with a guy who has a Parts Unlimited account. They have russell and some other line manufacturers too ... im wondering if someone can just tell me the length or whatever info i need
- lowkeyfilmz
15 Aug 2012 13:29
I know the guys at clearwater hose and Hydralic can make anything if they know the sizes.
They made some custom lines for my softtail.
