are police model forks wider?
  • timber
  • timber's Avatar Topic Author
12 Jun 2006 13:14
#53984
are the police model forks wider? and do they run a wider front tire? smaller front tire?
  • Pterosaur
  • Pterosaur's Avatar
Re: are police model forks wider?
12 Jun 2006 13:25
#53986
As far as I know, it's the same front end as the street KZs/LTDs - tubes and lower legs. Any differences would be in the triple trees, and while I won't swear on a stack of bibles just yet, I'm pretty sure they're the same as well.
A quick possibility is to check buykaw.com and check the triple tree part numbers for like-year cop/street models. That isn't a lock for the right answer, but it's a start...
www.buykawasaki.com/Default.asp
They do look bulkier because of the rubber fork boots and on the "C" models, the aluminum light bar/windshield mount castings - but those are slip-overs.
Stock cop bikes used 18s' front & rear, streeters used 19' front and 16' rears...
  • timber
12 Jun 2006 14:54
#53997
i thought they used a 18" or 16" i thought they looked wider also. i thought the older ones ran the same but the newer one ran a little wider. its a start. thanks
  • craigpuckett
  • craigpuckett's Avatar
13 Jun 2006 08:29
#54187
the cop bike wheel is wider between the brake disks and the triple trees are wider too,the fork legs are the same size but you can't interchange wheels as the spacing is not right
I know this first hand as I have both a 95 cop bike and an 81 csr1000 with ltd wheels on it
  • Pterosaur
13 Jun 2006 18:46
#54339
Just for grins, I measured the forks center-to-center this evening and came up with 8-3/8" between the lower legs just above the fender on my 78.
I compared the '78 Cop with the '78 LTD 1000 triple tree part numbers and diagrams, and they are indeed different.
  • RV
  • RV's Avatar
31 Mar 2007 09:40
#125166
fork-tube spacing is difinitely wider; front wheels are 18's, using a 110/90/18 tire.
  • wireman
  • wireman's Avatar
31 Mar 2007 10:38
#125183
who wants to sell a set of cop bike triple trees they want to sell cheap?:whistle: :P
  • Pterosaur
31 Mar 2007 11:02
#125192
Wouldn't have a clue about cop trees for sale...
;) :ohmy: :unsure: :dry: :laugh: :woohoo:
...but I do happen to know where there's a set of KZ trees (and forks and swingarm and....) that's been treated like an Italian Army rifle - never used and only dropped once... :P
  • wireman
  • wireman's Avatar
31 Mar 2007 11:09
#125193
i want to run an 18" wire front wheel with a 120-130 front wheel but cant do it with a stock width front end.ive already got all the shiny stuff but i need wider triple trees and ill have to widen an ltd fender and replate it.:evil:
