gas tank
  • ironleg
  • ironleg's Avatar Topic Author
  • its not what you ride its why
gas tank
30 Jul 2012 00:09
#539495
im working on my 78 kz 1000 ltd i instaled a set of 1975 28 mm carbs and went to put the tank on and the gas valve hits the carbs ???? had the tank rubbers on the frame has any one else had this happen and what did you do to fix it ?????
78 1000 ltd current project
75 z1 900 Dragbike 78 frame GS 1100 swing arm yamaha rear wheel dyna-s dyna 2 step best time 12.02 1.59 60ft
71 harley shovelhead chopper
2002 harley springer softail
1999 yamaha 600 grizzly
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: gas tank
30 Jul 2012 14:24
#539560
You will either have to use a diffrent style petcock or maybe switch the carbs or try to rotate it a little to see if it will clear.
1977 KZ 1000 work in progress
