Need new master cylinder, help
  • mitch805
  • mitch805's Avatar Topic Author
23 Jul 2012 03:48 - 23 Jul 2012 03:50
#537806
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationHey guys, i just got a 78 kz400 b1 and I need to get a new master cylinder. It currently has the trapezoid shape MC that I was planning on rebuilding, but once i took it apart i found that the diaphragm was just about torn off and was pretty rusty inside. Figured i might as well spend a little extra and get a nice clean new one. My question is, what can i use for a replacement MC with little modification? Anyone try these? or
Anyone know of something else? Maybe more affordable? Please help, really want to ride this thing. Thanks
Last edit: 23 Jul 2012 03:50 by mitch805.
  • Killman
  • Killman's Avatar
  • Now with 99% more ducks
Re: Need new master cylinder, help
23 Jul 2012 07:07
#537819
I picked up a new radial Brembo MC for $60 last fall. Took some searching and waiting for the right part to come up.
I remember checking old forum threads to make sure the piston was the right size for my needs, and of course that it was sized for a 7/8" handlebar.
The radial was nice because I switched to a euro bar that was "narrower" than the mini apes, and with my new bar mount mirrors and fairing, I was really tight on handlebar space. And it just looks cool as hell. :)
1983 kz440 ltd
Quack
  • mitch805
23 Jul 2012 21:48
#538018
Those are sweet, but i cant find one less that 200 bucks. Are you still using the stock caliper?
And does anyone know if the other ones will work?
  • ramtough_63
  • ramtough_63's Avatar
23 Jul 2012 21:54
#538020
im using one like the 2nd one you listed it was listed for a katana they will normally run one auction style with a starting bid 49.00 i think i gave about 55.00 and it has been fine
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • mitch805
23 Jul 2012 22:06
#538024
awesome. are you using the stock caliber? and does the brake light switch work with out any mod.?
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
23 Jul 2012 22:18
#538030
brake light switch will be easy. just show us what u get and we'll walk u through it. just about any master with the right size piston will work for u. just pay attention to the shape of the bars on yours and the donors for a close match. some bikes have bars with handles that droop. this could necessitate an oil level window that is in a weird position for your application, but would still work.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
The following user(s) said Thank You: mitch805
  • ramtough_63
23 Jul 2012 22:22
#538033
mitch805 wrote: awesome. are you using the stock caliber? and does the brake light switch work with out any mod.?
yeah everything else is stock on the front brakes
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • adventurekz
  • adventurekz's Avatar
  • proud owner 77 KZ400,370cc Bultaco Frontera
15 Aug 2012 18:19
#542825
Try www.partsnmore.com I've seen some universal fit master cylinders there.
Good Luck!
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
15 Aug 2012 18:37
#542826
i used to build and ride ducatis, the aftermarket brembo radials are only very slightly different than the 748 999 848 1098 1198 stockers, look for them on ebay or duc sites, there great cause the direct mounted reserviors.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
