spedometer housing
  • pete greek1
  • pete greek1's Avatar Topic Author
spedometer housing
22 Jul 2012 16:13 - 22 Jul 2012 16:36
#537687
what is the best lubricant for the housing, & the tach,& speedo cables ?..& should new cables be lubed.Pete
Last edit: 22 Jul 2012 16:36 by pete greek1. Reason: added another question
Re: spedometer housing
22 Jul 2012 21:11
#537717
Speedo gear housing should be greased and new tach and speedo cables should be given a light coating of grease. I use Mobil-1 synthetic wheel bearing grease. Clutch and throttle cables should be lubed with motor oil. Ed
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
22 Jul 2012 22:13
#537736
PJ1 makes a great cable lube and they have a kit with the mechanism that injects the lube into the cable sheath.
Bel Ray waterproof grease has worked for me for greasing things.
New cables come lubed but you should lube them anyway. Peace of mind.
  • pete greek1
23 Jul 2012 00:27
#537782
Thanks Ed, I believe napa carrys the mobile 1 wheel bearing grease,...DSB 1000, where can I pick up that kit Thanks...Pete
  • pete greek1
25 Jul 2012 00:13
#538404
O.K. I loaded up the speedo gearbox with Mobil 1 synthetic grease, ...now I havent replaced the cables yet, & could"nt find PJ1 at any of the local motor cycle/auto parts stores,....but I looked at my stash of goodies I borrowed from work before I retired, & I have a can of CPI correl lube 800 , when I googled it...it sounds like its more than good enough,...has any one ever used this lube ???...Pete
25 Jul 2012 00:21
#538411
I haven't used the CPI product, so I can't say. I use the Mobil-1 synthetic grease on the inner tach and speedo cables. I just slip out the inner cables, wipe them clean, put a glob of the grease on a rag, and using that put a thin coat of grease on the inner cable. No need to load up the inside of the outer cable with grease as the service manual only calls for a thin coat. Ed
  • pete greek1
25 Jul 2012 00:35
#538416
Ed I bought the mobil 1, but I have the correl lube, & its in a spray can with tube, & the price was right, if you got time google it , & let me know what you think,..I think it woughd be a little easyer to just spray into the cable, since I already have it...Thanks ...Pete
25 Jul 2012 08:01
#538461
I looked it up (below). I would think it should work fine. I would slip out the inner cable first and wipe the old gunk off (they get a bit nasty after a while) and then apply the lube to the inner cable before putting it back. My concern about spraying it into the cable is that it might build up near the end of the cable you're spraying it into before making it all the way through the cable. Also, keep in mind it only takes a light coating rather than fully loading the cable. Ed
www.cplubricants.com/industrial-lubricants.html
  • pete greek1
25 Jul 2012 08:43
#538467
Ed,they are both new cables that I havent instaled yet, so I figure I"ll pull the inner cables out , & wipe them off, then spray the inner cable down,then spray the inside of the outer cable, & let any lube run out before installing the inner cable, then install them on the bike...Pete
25 Jul 2012 08:59
#538469
Sounds like a good approach. When you pull the inner cables be careful to see if there are some tiny washers on one of the ends. I think some have them and some don't, but if they do and you drop one they can be hard to find on an asphalt driveway (guess how I know? :laugh: ) Ed
  • pete greek1
25 Jul 2012 09:24
#538472
10-4 Ed, I already see a tiny rubber washer on one end of the speedo cable, while its still in the plastick bag,...I"ll keep my eyes open...Thanks..Pete
