83 kz550ltd m1 front brake disc
  • tk89123
  • tk89123's Avatar Topic Author
20 Jul 2012 22:34
#537389
I'm reasonably certain that my bike was wrecked by a previous owner. It has a slightly warped front brake disc that doesn't look like other 550ltd brake discs on fleabay. I'm thinking that the front end and wheel may have been replaced with parts from another model. Here is a photo of the front wheel/brake disc. Does anyone have any input as to whether it is correct or from what bike it might be from? I like the bike and want to replace the disc but not sure what I have exactly. I replaced the brake pads with pads I got from Z1 and they are fine. Thanks in advance.
Tom
Las Vegas, NV
'83 KZ550LTD M1 shaftie
  • martin_csr
  • martin_csr's Avatar
Re: 83 kz550ltd m1 front brake disc
21 Jul 2012 10:05 - 22 Jan 2013 20:59
#537439
never mind doh
Last edit: 22 Jan 2013 20:59 by martin_csr.
  • myro
  • myro's Avatar
21 Jul 2012 14:16
#537465
Attachment IMAG0403.jpg not found
Hope that helps lmk if you need a different angle
  • tk89123
21 Jul 2012 18:35 - 21 Jul 2012 18:38
#537507
Thanks guys. Between myro's photo and another one that I found online, it's definitely the wrong front wheel but still the same 19" diameter. I saw no markings on it other than Kawasaki, Enkie and made in Japan. I'll get another wheel and disc from fleabay then. From the diagrams on the Kawasaki parts site and the part numbers, it looks like any 550ltd wheel from the early '80's should work although the disk numbers are slightly off, just the last 4 digits a little different but the drawings look the same.
Tom
Last edit: 21 Jul 2012 18:38 by tk89123. Reason: Added a couple of new lines.
  • martin_csr
21 Jul 2012 22:00 - 22 Jan 2013 20:59
#537538
