Changing Steering Stem Angle
  • NakedFun
  • NakedFun's Avatar Topic Author
18 Jul 2012 10:44
#536742
All,
So I am into my "Sanctuary" type build of my '76 KZ900. Welding and fabricating the frame with a "Leon" (thanks guy!) gusset kit and redoing rear set mounts, moutning up my new suspension, new upper shock mounts, oil cooler mounts, GSXR steering damper integration, etc.. My question is, should I steepen the steering stem angle in order to improve turn in? Has anyone else performed this modification? If so, how did you jig up the head stock to prevent misalignment during the fabrication? Did it end up being worth it? Any input would be appreciated.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • ramtough_63
  • ramtough_63's Avatar
Re: Changing Steering Stem Angle
18 Jul 2012 11:36
#536750
If ur taliking about raking the frame Les raked his and for the ney sayers who say long and low wont wont turn in I highly reccomend climbing on les' bike.
Give Les a shout out he may be able to Stear you in what needs to be done
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • NakedFun
18 Jul 2012 11:40
#536754
Thanks for the info, but I was actually thinking about less rake and steepening the angle of the head. Eitehr way, his experience and feedback would still be beneficial.
Cory
1976 Kawasaki KZ900
  • ramtough_63
18 Jul 2012 11:50
#536756
the offset of the trees pulls the forks closer to the stearing head I'm sure the other guys can give you a more technical aspect of the swap as I am learning it all myself
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
18 Jul 2012 12:15
#536762
Do some homework on rake and trail! It will give you a better idea of what your going to get when you start playing with rake. Going with the newer front ends reduces offset alot of times which slows steering a little but improves stability a higher speeds. There is no free lunches when it comes to this. Watch the road racers, they are experiencing head shake when they upset the chassis even a little, they run a compromise of quick turning and high speed stability. They actually change this depending on the course they are running. Where do you want to be needs answered.
Les
  • DrWhizBang
  • DrWhizBang's Avatar
18 Jul 2012 12:31
#536768
I would expect you can accomplish something similar by sliding the front forks up in the trees (have to watch for clearance!) and putting longer shocks on the rear. However, it makes more sense to have a target geometry before changing things up - there are many rake/trail/offset calculators out there. You don't want to de-rake the head and then find out you have massive stability issues.
KZ650C2 w/810CC in Saint John, NB
-- a sleeper, methinks.
  • NakedFun
18 Jul 2012 12:46
#536772
Understood. The unfortunate thing about this, is that you won't truly know what it will be like until you ride it! Then everything is PC'd and pretty and you hate to cut into it to make changes. I have several books and articles specifically geared aroound motorcycle frames and their geometry. If this was a car, I would be up-to-snuff to make this type of change and know what to expect. Will continue to keep reading and make an a more informed decision or guess.... Ultimately, looking at bring the level of handling to where my SV's and ZRX's are at.
Cory
1976 Kawasaki KZ900
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
18 Jul 2012 12:52
#536775
Hit Mark1122 up, I think he's got a pretty good handle on making one do the twisties which is where I assume you are going.
Les
  • damarble
  • damarble's Avatar
18 Jul 2012 12:54
#536776
DrWhizBang wrote: I would expect you can accomplish something similar by sliding the front forks up in the trees (have to watch for clearance!) and putting longer shocks on the rear.
That's where I am now and it's too squirrely at speed, feels like I'll get a slapper any minute.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
18 Jul 2012 13:16
#536781
what r your intentions for the bike when done, road race track, drags, or street?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
18 Jul 2012 13:23
#536782
That's a direct result of reduced trail. Going with a newer style inverted front end corrects some of that by having a lower offset in the trees. The ZX's have around 26mm offset, The GSXR's have around 30mm offset, Stock KZ's have around 60mm offset. Find a rake and trail calculator and punch in those numbers and you'll get the picture.
Les
  • NakedFun
18 Jul 2012 13:59
#536794
I am using ZRX1200 front forks and rear suspension. As far as application for the bike, looking for a nice street going, canyon carver. No racing will be in the cards for this one.
Cory
1976 Kawasaki KZ900
