Fork swap
  • Kevin STP
  • Kevin STP's Avatar Topic Author
Fork swap
17 Jul 2012 17:54
#536611
How do you figure which forks can be used to swap.I have a 1983 Spectre 750.
83 Spectre 750
  • jarrad
  • jarrad's Avatar
Re: Fork swap
18 Jul 2012 01:56
#536695
mate just find the forks you want with a set of triples attached, then its just a matter of swapping the stem's over, which may be press in press out or may need some machining.
  • Kevin STP
Re: Fork swap
18 Jul 2012 13:58
#536791
I was wondering if there were forks that would be a straight up swap.Not looking to change the height or frame geometry, I like the handling as is.
83 Spectre 750
  • TexasKZ
  • TexasKZ's Avatar
  • Away
Re: Fork swap
18 Jul 2012 13:59
#536793
If you like the handling as is, why swap?
  • Kevin STP
Re: Fork swap
18 Jul 2012 17:11
#536836
I meant that the design works for me but I would like to improve the ride.It seems a fairly common upgrade.
83 Spectre 750
  • Weber
  • Weber's Avatar
Re: Fork swap
26 Jul 2012 20:32
#538854
Go to allballs racing.com Put in your frame and it will tell you all of the fork combinations that will work....
  • Carr_113
  • Carr_113's Avatar
Re: Fork swap
26 Jul 2012 20:42
#538857
Thanks for that resource, Weber. Since we're on the subject:
www.ohiocaferacers.com/OCRTubeSizes.pdf
www.ohiocaferacers.com/OCRStemSizes.pdf
'74 Z1-A
'80 KZ750E
'80 GS750E
'81 KZ440
'79 XS650 (needs love)
'72-'73 CB350 (3 or 4, in pieces)
  • Carr_113
  • Carr_113's Avatar
Re: Fork swap
26 Jul 2012 20:45
#538859
Sorry, OP - I think you'll want to research different fork oil and replacement spring options instead of buying entire assemblies. I don't think there's really a better way to get what you're looking for. Check the forums to see what others are doing with your bike model.
'74 Z1-A
'80 KZ750E
'80 GS750E
'81 KZ440
