swing arm measurements
- BigBlockT
11 Jun 2006 08:47
does any one know the pivot point measurements of these swingarms looking to swap into a z1 "2000 or newer zx6r,636,gsxr 600" as these are pretty straight?
- gpzrox
Re: swing arm measurements
12 Jun 2006 02:43
I believe that the GSXR stuff is almost a direct swap into a GPZ, and I just happen to have a GPZ swingarm around, just a minute so I can make sure of the numbers:
yep, tape reads 9".
So I bet the GSXR is very close to that number, I'm sure a seller would have a tape around to let you know.
Now on something that involved, if I were doing the job, I would measure the Z1 swingarm myself to be completely sure of my measurements. Your gonna want to pull the swingarm anyway eventually, and it couldn't hurt to grease the arm bearings.
There are also some posts in the archives. And if your arm measures 9", then I can direct you to some other sites that go into detail much like in the archives.
yep, tape reads 9".
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
- wireman
12 Jun 2006 04:34
z1 should be around 9 1/4" depending on who you ask.
