Rear Axle ???????????????
  • 4TheKZ1000
  • 4TheKZ1000's Avatar Topic Author
15 Jul 2012 22:35 - 15 Jul 2012 22:43
#536207
my rear axle has no cotter pin hole. It also dosent have a castle nut???????? what do I do loctite it. seems dangerous to me....
Last edit: 15 Jul 2012 22:43 by 4TheKZ1000.
Re: Rear Axle ???????????????
15 Jul 2012 23:09
#536214
4TheKZ1000 wrote: my rear axle has no cotter pin hole. It also dosent have a castle nut???????? what do I do loctite it. seems dangerous to me....
The ideal solution would be to obtain and install the "correct" rear axle, castle nut, and cotter pin (or better yet, a hitch clip pin).
May use the link in my signature for help with navigating kawasaki.com, which says the axle is an "inactive" part (which usually means no longer available through Kawasaki dealers), and says the castle nut remains "active."
These parts are sometimes listed on ebay, where searching for a particular part number is often helpful.
I don't know where the existing axle and nut came from. :huh:
Good Fortune! :)
  • 4TheKZ1000
15 Jul 2012 23:13
#536215
the guy I bought it from claimed 80 kz1000 E axle.
  • dejavoodo41
  • dejavoodo41's Avatar
15 Jul 2012 23:16
#536218
Mine is the same way and it has a nylock nut on it and it's been fine for the last 4 years. I just make sure to check it periodically to make sure that it's not working loose. I've ridden like this for over 30K miles with no issues.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
  • 4TheKZ1000
15 Jul 2012 23:20
#536221
ok, thanks.
  • 4TheKZ1000
15 Jul 2012 23:27
#536226
No eBay APP ID and/or Cert ID defined in Kunena configurationhere is another E axle ..... just like mine??
  • Motor Head
  • Motor Head's Avatar
15 Jul 2012 23:35
#536229
A shaft drive bike has no adjustment slots for where a chain drive bike does. If you have a chain, get the correct axle and nut/ cotter or hitch pin. For safety more than anything else. You don't want the axle coming loose that's for sure.
  • 4TheKZ1000
15 Jul 2012 23:42
#536233
yep, its a shaft drive axle....anyone need it. $10.00 + shipping ..... PM me
its stright and nice.
  • Motor Head
15 Jul 2012 23:49
#536234
If it is a shaft drive, then the axle you have should be correct, no castle nut, just a self locking.
