problem with moving the throttle
- joshjones84
14 Jul 2012 16:30
after installing my clubman bars, it seems that the throttle will not move free at all. i have the 7/8" bars. what can i do to solve this problem? should i try stripping the paint off the handle bars?
and also, when i have the throttle off the bars, it moves freely. i lubed them up before putting them on.
82 KZ550 LTD
- dejavoodo41
Re: problem with moving the throttle
14 Jul 2012 17:13 - 14 Jul 2012 17:18
I would make sure that nothing is binding in the throttle mechanism itself. I had an issue like this once and it was the cable had somehow worked its way out of the slot inside the throttle and was keeping it from rotating. Once I got it in right it was fine. I'd also make sure that there's no kinks in the cable due to the way they are routed and lastly check on the carb end make sure that nothing is binding on that end. Since it's working off the bars there may be some binding when it is tightened down. I'd install it loosely and make sure that it rotates before tightening it down and check to see if there is an issue of it being too tight and binding the mechanism when it's tightened down.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Last edit: 14 Jul 2012 17:18 by dejavoodo41.
- joshjones84
16 Jul 2012 10:31
i ground off the paint on the handle bars and took a dremel to the inside of the throttle handle. it works great half way up handle bars but once it goes past half way, it does the same thing. like its dragging on something. i want to get my bike running this week but if i dont get this problem solved, i cant!!!! its way to dangerous to let this issue go. i was wondering if anyone has put a 4 wheeler throttle on a kz. could i do it with one throttle cable hooked to my carbs?
82 KZ550 LTD
- Motor Head
16 Jul 2012 10:37
You could hook it to a Thumb throttle, you only need one cable, preferably the Pull cable. Make sure you get enough for full throttle.
It should be easy to get the Original throttle to work on the new bars, I've never seen one hang up like you say.
Don't ride it without the throttle returning, even running it could be bad if it over rev's.
- joshjones84
16 Jul 2012 10:50
i just checked on ebay and doesnt look like they have much of a selection. could i use my throttle cable or would i have to find something else?
82 KZ550 LTD
- joshjones84
16 Jul 2012 10:54
No eBay APP ID and/or Cert ID defined in Kunena configurationyou think this will work?
82 KZ550 LTD
- nobody
16 Jul 2012 11:20
do you really want to turn it loose with out a good grip on it
- joshjones84
16 Jul 2012 12:10
i figured it would be different. but to save money, ill just grind the shit out of my throttle handle and see where that leads me.
82 KZ550 LTD
- peter1958
16 Jul 2012 12:30
Does your throttle housing have a nub on it that went into the hole in old bars!!
www.kzzone.com/
- mwriders
- if I only had a brain
16 Jul 2012 12:45
Ran into the same problem. Turned out that my new bars were rusted internally, and that rust had worked its way onto the inside of the throttle tube. Repeated washing with a bottle brush eventually cleaned it up.
1980 Kawasaki KZ440B (brand new eBaby)
1998 Ducati 900S (gone)
1978 BMW R100S (gone, damn it)
1975 Yamaha RD350 cafe (gone)
1986 Yamaha XJ650 Seca (gone)
1981 Kawasaki KZ440LTD (gone)
1969 HD Sportster (gone
1966 Honda CB160 (gone, damn it)
1965 Suzuki 80
1965 Suzuki 80
