kz750 stem head
  • DBINWI
  • DBINWI's Avatar Topic Author
kz750 stem head
14 Jul 2012 03:51
#535797
Recently picked up a 750 twin. The front wheel alignment is off a little bit- that is to say going down the road staight the bars have to be slightly to the right. Question -- do I loosen the triple tree and stem head bearing to realign this ?
  • 893cv
  • 893cv's Avatar
Re: kz750 stem head
14 Jul 2012 14:17
#535862
First check that the bars are not bent. Next loosen the "bar holders" at both the handlebar and below the upper triple. Tighten those back to spec, then if needed loosen the fork tube clamp bolts, the stem bearing adjustment bolt and rings, the fender mount bolts and the axle clamp bolts. Tighten these all back to spec. If things are still not right, take a look at the rear wheel allignment. If things are still not right the fork tubes may be bent.
1980 kz1000 LTD
1978 Z1R
