fork fluid kz 750
  • Boediddly
  • Boediddly's Avatar Topic Author
fork fluid kz 750
13 Jul 2012 22:11
#535750
can one of you guys give me the amount of fork fluid for the 76 kz 750 b?
Re: fork fluid kz 750
13 Jul 2012 22:43 - 14 Jul 2012 08:18
#535756
Just adding a specific amount of fork oil doesn't ensure the fork oil level in both tubes is equal or correct. You will need to know what the fork oil level should be, and this can be found in the Kawasaki Service Manual. You measure this with the front wheel elevated off the ground and the forks fully extended. Then you measure from the top of the fork tube to the fork oil (with the springs in place) using a wood dowel or other appropriate tool and adjust the oil level until it matches the spec in the Kawasaki Service Manual. You then ride around a bit to let everything settle into place than check again. I find 15w Bel-Ray fork oil works really well. Ed
Last edit: 14 Jul 2012 08:18 by 650ed.
  • bountyhunter
  • bountyhunter's Avatar
14 Jul 2012 01:24
#535785
Here you go:
  • trianglelaguna
  • trianglelaguna's Avatar
14 Jul 2012 11:21
#535831
progressive fork springs are not too much $$$ and will help too.....just saying...most folks dont know or care enough to check the fork oil,or can even take the caps off......
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
14 Jul 2012 11:59
#535845
Be sure to loosen the upper triple tree clamps when trying to remove the fork caps; otherwise they can be REALLY hard to unscrew. Ed
