Handlebar Clamp Interchangability
- dejavoodo41
13 Jul 2012 00:56
I'm thinking about changing from my current setup on my 77 Kz 1000 from clip ons and barely functional gauges to a superbike bar and stock gauges and was wondering if there is any difference in the handlebar clamps between the years? I've done quite a bit of searching but really couldn't come up with much. Any info that you guys could give me would be most appreciated.
Roger
Roger
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Re: Handlebar Clamp Interchangability
13 Jul 2012 09:40 - 22 Jan 2013 20:41
Do you mean the 2 handlebar holders that clamp the bars to the upper triple tree? If so, checking at PowerSportsPlus, it appears that virtually every KZ uses the same bar holders.
Last edit: 22 Jan 2013 20:41 by martin_csr.
- dejavoodo41
13 Jul 2012 10:12
That's exactly what I was looking for. Thanks for the info.
