Ridin a Shaftie.
  • Kevin STP
  • Kevin STP's Avatar Topic Author
Ridin a Shaftie.
12 Jul 2012 19:56
#535495
Took a while to get the hang of throttle managment,before that my Spectre was a bit jerky.Is this common with a shaft drive?
83 Spectre 750
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Ridin a Shaftie.
12 Jul 2012 21:47
#535514
Rear will rise up when you twist it and drop when you get off,just the opposite of chain drive.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Rickman
  • Rickman's Avatar
13 Jul 2012 16:04
#535700
Proper slack in throttle cable? I found it easier to use with just a little play at the idle-end of travel.
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
  • Del_Herring
  • Del_Herring's Avatar
13 Jul 2012 16:48
#535703
Mine's like that too. The throttle adjustment will probably help a little, but I found an old review from when the Spectre was new once, and even at the time they mentioned that there seemed to be more slop in the driveline of the spectre than on the chain variants. So I wouldn't be concerned about it unless it's enough of a jerk to make it hard to ride.
1983 KZ750-N2 Spectre
  • Del_Herring
14 Jul 2012 02:59
#535791
Yea, link's here if you wanted to glance at it. Has a decent bit of information all around as well. I actually read this before buying the bike, and it convinced me I'd be happy with my decision.
www.motorcyclespecs.co.za/model/kawasaki..._z750n%20spectre.htm
  • Kevin STP
14 Jul 2012 23:36
#535959
Thanks for the replies,I have slackened up on the throttle cable and it helps. I was wondering if the cush hub plays a part?
83 Spectre 750
