Which Chain?
  • tbaumga2
  • tbaumga2's Avatar Topic Author
Which Chain?
12 Jul 2012 19:35
#535490
I've tried searching the forums w/o any luck
Can anyone tell me what size/type chain I'd need for an 81 Gpz 550, or at least where I can find this information. Motorcycle Superstore and others just list chains as "universal" which isn't helping. Also, my local shop refused to tell me which size I needed unless I committed to letting them install it for me :huh:
Another wrench in the works -- the body/chassis of the bike is an 81, but the motor is an 84. Will the chain size be the same for both years?
Thanks!
Re: Which Chain?
12 Jul 2012 23:53
#535553
Would check with
www.z1enterprises.com/
Good Fortune! :)
  • tbaumga2
Re: Which Chain?
13 Jul 2012 10:08
#535623
I tried that, it looks like the site is down tho -- keep getting "an error occurred, contact system admin" message when I click on parts or brands
  • osage
  • osage's Avatar
Re: Which Chain?
13 Jul 2012 10:32
#535628
Yeap it's down. Try giving them a call. I was going to order sprockets and chain for my 82 yesterday but it was down then.
If your just looking to get the size it should be stamped on the side plate of the chain link. It least it's on my factory chain that way "630".
Is your chain shot? If so old sprockets will be hard on a new chain.
I'll be going to a 530 this time. Z1e has a page that explains the conversion for 630 to 530. Hope they get their server issue fixed soon.
1976 KZ750B1
1982 KZ750H3
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Which Chain?
13 Jul 2012 11:28
#535645
According to Kawasaki.com's part diagrams, your bike uses a 530x100 link chain when used with the stock 16F/38R sprocket set.
I use a RK 530XSO chain on my 1000 and really like it, fwiw.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
Re: Which Chain?
13 Jul 2012 15:30
#535687
Just call us to order.
The web site has been a pain in the butt this week - or should I say the support company we use for the site (and soon to be ex-support). They moved the web site to a new server on Monday and totally screwed it up. I don't know all the details, but somehow they overlayed license keys or something like that and have not been able to reactivate some of the software behind the site. We are hoping to have a web site up and running in the next 24 hours. It may not be the old site - we are scrambling to ready planned new web site - just 3-4 weeks before it was due to be ready - so it might be a little rough around the edges.
The following user(s) said Thank You: osage
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
Re: Which Chain?
13 Jul 2012 15:57
#535695
Jeff.Saunders wrote: Just call us to order.
Your web site provider sounds like they are a bit shoddy Jeff. Sorry you are having the troubles. I have done a lot of server migrations, which includes our software, their users, their database and third party software. Should be almost seamless to the users. We always hand over the new server to to the customer for testing while the old server is still operational. This way, they can try testing it (albeit not under load) before making the switch. Of course the customer is not a good tester, so they usually forget to test printers and so forth. But my point is, they really messed up. They should not have put you in a position like this that can cost you money. How can they have run into licensing issue unless there was zero real time testing done? I have gotten errors when navigating your site before. So the software was buggy anyhow. Just learned how to recover when it did happen without losing too much time or to call up instead. Hope the new software works out for you. Good luck.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • tbaumga2
Re: Which Chain?
16 Jul 2012 00:04
#536238
alright thanks! I'll give z1 a call
