Hub weight
- zukdave
Hub weight
09 Jul 2012 23:34 - 09 Jul 2012 23:41
So what would be lighter a 78 KZ1000 disk brake hub and brake set up
or my 80 KZ650 drum brake set up.
I have both set up's and will lacing in a 17x4 Alum rim
so can go with either one.
The drum brake hub's still laced to a rim
and the disk set up ain't so weighing them don't work.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 09 Jul 2012 23:41 by zukdave.
- wireman
Re: Hub weight
10 Jul 2012 00:49
probably the drum
