Spectre 750 shock renew.
- donthaveakawman
Re: Spectre 750 shock renew.
26 Oct 2012 02:16apparently there is a phillips screw on the side of each fork on the bottom, and an air filler on the top i think you can figure it out.Kevin STP wrote: I may get to try this over the weekend and will post results.The manual instructions for this are odd-it lists the air volume and the oil volume.Completely fill shock with oil and then dump out an amount equal to the air volume.Seems way to scientific.Maybe I just don't get it!!
- Del_Herring
26 Oct 2012 03:01
He already did...
That said, I'm still trying to get my hands on those specs, since they're conspicuously absent from whatever manual I have.
1983 KZ750-N2 Spectre
- donthaveakawman
26 Oct 2012 05:05Kevin STP wrote: I may get to try this over the weekend and will post results.The manual instructions for this are odd-it lists the air volume and the oil volume.Completely fill shock with oil and then dump out an amount equal to the air volume.Seems way to scientific.Maybe I just don't get it!!
15 psi max don't remember the oil volume.
- donthaveakawman
26 Oct 2012 05:07
my local library small engine repair reference database in the motorcycle section for the kz750 h1 says......
- donthaveakawman
26 Oct 2012 05:16oh no someone hacked my shit so i can't get in theredonthaveakawman wrote: my local library small engine repair reference database in the motorcycle section for the kz750 h1 says......
- Del_Herring
02 Nov 2012 18:57
Still in the need for the rear oil specs. I can't find any manuals that have this spec in them. They have the front forks, but not the rear shocks. And dont have a kaw, i believe you're looking at the fork spec. the rears run at around 40 psi.
- donthaveakawman
02 Nov 2012 21:23
try kz.bike-night.com/manual.html i am not sure if spectre is even in there, but you could give it a try. Some of it is missing. be careful, the format is not old computer friendly, but i think you will be alright.
Attachment pdf_file_pediphile_michael_jackson1.jpg not found
- wireman
02 Nov 2012 22:56:woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:donthaveakawman wrote: try kz.bike-night.com/manual.html i am not sure if spectre is even in there, but you could give it a try. Some of it is missing. be careful, the format is not old computer friendly, but i think you will be alright.
- Del_Herring
02 Nov 2012 23:54
Unfortunately doesn't cover the shafties, but it is a lot more thorough than the shaft model service manual I have, so thanks anyways, it'll be better than what I've got when I'm playing with the engine.
And thank you for that public service announcement about PDF Files, it's important to make people aware.
