Anybody cut off and reposition their headstock?
  • damarble
  • damarble's Avatar Topic Author
05 Jul 2012 13:10
#534018
I keep creating more problems for myself. Determined to retain my 19" front with USD forks, I've found my tire will be backed up uncomfortable close to my exhaust. Nearly every USD swap I've seen has used the smaller wheel from the donor bike and don't have clearance issues.
Adding rake will of course compound the problem of shorter USD forks, but I'm already assuming I'll be getting dropped triples. Also 1-2 degrees should really be enough, no need for extreme.
It looks fairly straight forward to cut out the old headstock, reposition it for a couple degrees more rake and even lower it down a hair.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Anybody cut off and reposition their headstock?
05 Jul 2012 13:15
#534020
thinking that you "can do it"is the hardest part :lol: !
all that is left is execution.
i would make sure i had all the parts i planned to use,and make it look like i want it to.
keep us posted,
  • damarble
05 Jul 2012 13:42
#534026
I am not looking forward to it I assure you. A jig of sorts will need to be made to keep it square. I trust my welding and fabrication, I put my life in my hands any time I drive my hand built custom suspension Explorer and now the KZ withcustom shock mounts in back. It's the tedious detail work of aligning everything and calculating angles that puts me off.
  • wireman
  • wireman's Avatar
05 Jul 2012 23:15 - 05 Jul 2012 23:15
#534145
Attachment popcorn.gif not found
B) B) B) B) B)
Last edit: 05 Jul 2012 23:15 by wireman.
  • ramtough_63
  • ramtough_63's Avatar
05 Jul 2012 23:41
#534151
do you have any pix's of it mocked up I am curious about how close it it I am planning on the same set up having my axle and spacers made to fit my usd forks.
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • kzz1king
  • kzz1king's Avatar
06 Jul 2012 00:50 - 06 Jul 2012 00:54
#534175
I had one I could not get a title for without jumping through a bunch of hoops. I made a slice on each side of the stem and removed, leaving the portion attached to the frame. I then welded the donor stem to it and bumped it out a couple degrees at the smae time. It was easy to keep everything straight. I have also just cut the downtubes, sleeve them and add in a few inches. Downside is it also raises the front.
Wayne
Home built KZ1000 turbo setup
Last edit: 06 Jul 2012 00:54 by kzz1king.
  • spark23ca
  • spark23ca's Avatar
06 Jul 2012 01:19
#534180
a little grindin welding and maybe even heat ...oh and one of them fancy little magnetic levels with digital degrees right on it ..clamp er up and weld
1982 kz 1000 ltd ..someone started to make a bobber out of it and realized it didnt' run and they didn't know how to run their wrenches
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
06 Jul 2012 08:52 - 06 Jul 2012 08:55
#534220
I'd push to get it on a jig, good time to square things up.
Attachment framerakeZ1R007.JPG not found
Attachment framerakeZ1R006.JPG not found
General idea of what to do. :)
Les
Last edit: 06 Jul 2012 08:55 by les holt.
  • damarble
06 Jul 2012 11:54
#534251
Don't finish off the popcorn just yet, I have a whole riding season to make it through before I start frame work.
I can get some pics, I just compressed the forks to the same height as the USDs and mentally subtracted 1.5" to remove the leading axle. It physically fits at static height but might not when fully cycled.
Good suggestions guys.
