what kz550 do i have?
- joshjones84
03 Jul 2012 18:03
i have a kz550 ltd and i need to buy parts for it. how do i know if i have a A3, C3, or an H1? what is the difference ?
82 KZ550 LTD
- loudhvx
Re: what kz550 do i have?
03 Jul 2012 20:18
If it's an LTD, it is a C3.
A3 is a standard with 18" rear wheel. (Yours is 16".)
H1 is the mono-shock gpz 550.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- joshjones84
04 Jul 2012 05:39
that sucks! i ordered a clutch cable for an a3! will it still work? i hope?
82 KZ550 LTD
- faffi
04 Jul 2012 06:28
Chances are it can be a bit short, depending on what handlebars you're using.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
1980 F1 engine
B1 Points ignition
- joshjones84
- faffi
04 Jul 2012 08:47
Then the A3 will fit better than the C3 cable
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
Last edit: 22 Jan 2013 20:28 by martin_csr.
- joshjones84
05 Jul 2012 03:50
yeah, i put the cable on tonight and it fit great. its about 3-4" shorter! faffi, are those the only differences in A3, C3 and H1?
82 KZ550 LTD
- loudhvx
05 Jul 2012 18:18 - 05 Jul 2012 18:20
To see all of the differences in those 3 bikes, you can grab the factory manuals from my signature.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 05 Jul 2012 18:20 by loudhvx.
