Length of clutch cable for KZ550-C3 LTD (1982)
  • Bunty27
  • Bunty27's Avatar Topic Author
26 Jun 2012 01:32
#531805
I replaced the stock handlebar on my bike and tried to replace the broken clutch cable with one from Motion Pro. However, it turned out that the cable is a bit too long for the clutch lever on this handle bar. The cable is 54.5 inches with 3.5 inch slack. I measured the length from the clutch lever to the clutch following the usual path along the frame to be around 46 inches. It does look like MotionPro makes cables that are 48.5 inches and 50.5 inches long with the same 3.5 inch slack. Can one of you pros recommend the one to choose among the two options. I know I can order custom cables but I would rather not wait that long. Thanks in advance for your help.
1982 KZ550 LTD
  • Bunty27
Re: Length of clutch cable for KZ550-C3 LTD (1982)
27 Jun 2012 00:29
#532032
No advice from anyone here? :)
1982 KZ550 LTD
  • Motor Head
  • Motor Head's Avatar
27 Jun 2012 01:01
#532035
Pictures of the Bars, and set up might get some in put from the guys.
but I would have the cable set up normally, then disconnect it at the lever, holding along side, possibly zip tie it, then rotate through the steering full sweep. Adjust till it all looks good. Place a marker there where the length looks right, then take it off and measure. Get a slightly longer than shorter as you don't want it to bind when steering.
  • martin_csr
  • martin_csr's Avatar
27 Jun 2012 10:26 - 22 Jan 2013 20:20
#532070
Last edit: 22 Jan 2013 20:20 by martin_csr.
  • Bunty27
30 Jun 2012 12:32
#532784
Thanks y'all but I realized I was doing the clutch adjustment incorrectly. As someone suggested here, the instructions for doing this are incorrect. I have the clutch cable installed now with the right slack and all!
1982 KZ550 LTD
