Changing speedo from MPH to KMH
- KZ1000inaus
- Luminous Red KZ1000 A2
24 Jun 2012 07:15
this may be a silly question but to change my speedo over to KMH is it as simple as just fitting something like these?
or does some work need doing on the internals?
kz900.com/decals-kz1000-a.html
- 0Z.Z1R Mk2
Re: Changing speedo from MPH to KMH
24 Jun 2012 08:04
I think you'll find it is that simple.....
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
- KZ1000inaus
24 Jun 2012 08:570Z.Z1R Mk2 wrote: I think you'll find it is that simple.....
Does anyone have any tips on getting the clocks apart?
- KZ1000inaus
24 Jun 2012 09:02KZ1000inaus wrote:0Z.Z1R Mk2 wrote: I think you'll find it is that simple.....
Just found this which looks like what i need !
kzrider.com/index.php?option=com_content...view&id=39&Itemid=11
24 Jun 2012 09:33
I don’t think that will work for you. Take a close look at the 2 dials. If your speedo is currently a MPH model when you are moving 80 mph the needle is pointing strait up in the 12 o’clock position. The kph dial shows 120 kph at the 12 o’clock position, so at the exact same 80 mph speed you speedo would read 120 kph. Not good – because 80 mph actually = 128.74 kph so the speedo would not be accurate. Ed
Attachment 00000_2012-06-24.jpg not found
24 Jun 2012 10:06
Japanese motorcycle speedometers are notoriously optimistic.
Needle pointing straight up at 80 is probably an honest 75 (or less).
75 mph = 120.7 kph
Under this theory, needle pointing straight up at 120 kph may reflect a more accurate road speed.
There's a thread around here somewhere about creating all sorts of diy speedo and tach faces.
Impress your passenger. Double 'em all. :lol:
75 mph = 120.7 kph
- 0Z.Z1R Mk2
24 Jun 2012 19:18650ed wrote: I don’t think that will work for you. Take a close look at the 2 dials. If your speedo is currently a MPH model when you are moving 80 mph the needle is pointing strait up in the 12 o’clock position. The kph dial shows 120 kph at the 12 o’clock position, so at the exact same 80 mph speed you speedo would read 120 kph. Not good – because 80 mph actually = 128.74 kph so the speedo would not be accurate. Ed
On closer inspection of those dials your right Ed...
I just had a quick look the 60 mph and figured that would be very close to our 100 kph.
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
