Left side control question
  • gwolever
  • gwolever's Avatar Topic Author
20 Jun 2012 00:18
#530446
Hey guys. Just got my new handlebars in and am having some trouble with space for the left side controls.
First of all, I can't seem to fit the left lever where I need it. There is a 2 prong connection that goes directly into the left hand control unit. Here are some pics:
Attachment 001_2012-06-19.JPG not found
Attachment 002_2012-06-19.JPG not found
Attachment 004_2012-06-19.JPG not found
The left hand control unit is already to far over, farther away from the lever/grip than it should be.
Any suggestions?
Secondly, what exactly is it that plugs into the clutch lever? On the stock unit there was a plug-in that hooked up to 2 black wire connectors under the tank.
Anybody know what that is for? Here is a pic:
Attachment 005.JPG not found
If it is not needed, is it possible just to cut that 2 prong connector off of my left hand lever to make more room for the left hand controls unit?
Any suggestions would help.
Thanks guys.
1982 KZ1000 CSR
  • Flyndrive
  • Flyndrive's Avatar
Re: Left side control question
20 Jun 2012 00:29
#530449
The connector is for you starter lockout. You have to squeeze the clutch to allow the starter to operate. It's a safety switch so if you start it in gear the bike won't take off.
1980 KZ 550A1
1985 GPZ 900R
  • gwolever
20 Jun 2012 00:41
#530456
Damn. That's what I thought it was looking at the wiring diagram. Just wanted to make sure. Well that sucks.
Now I have to figure out a way to hook that up and still be able to use the left hand control unit.
Thanks Flyndrive.
1982 KZ1000 CSR
  • martin_csr
  • martin_csr's Avatar
20 Jun 2012 09:52 - 22 Jan 2013 20:12
#530499
never mind
Last edit: 22 Jan 2013 20:12 by martin_csr.
  • wireman
  • wireman's Avatar
20 Jun 2012 09:55
#530500
Hook the wires under the tank to a toggle switch,instant anti theft device B)
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
20 Jun 2012 10:03
#530501
Flyndrive wrote: The connector is for you starter lockout. You have to squeeze the clutch to allow the starter to operate. It's a safety switch so if you start it in gear the bike won't take off.
Isn't it on the transmission?
That perch looks aftermarket.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • Motor Head
  • Motor Head's Avatar
20 Jun 2012 10:34
#530510
Kidkawie is right. The Perch is Aftermarket and the angle of the switch is wrong. The switch needs contact, so the wires would be connected to operate the starter solenoid.
  • gwolever
20 Jun 2012 15:06
#530547
Yes. The levers/perch are aftermarket.
The switch is built into it. The angle of the switch is wrong.
Is it possible to run the connection under the tank to a toggle switch and just cut off the switch on the perch so I can put my levers right up against my controls unit?
So I would just be hooking up the 2 black wires from the clutch switch to a toggle switch instead? Or is there more to it than that?
Thanks guys.
1982 KZ1000 CSR
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
21 Jun 2012 10:24
#530720
You don't need a toggle switch. Depending on how it works, just connect the two wires or leave them disconnected.
1975 Z1 900
2004 KX125
  • StreetfighterKz
  • StreetfighterKz's Avatar
21 Jun 2012 11:05 - 21 Jun 2012 11:06
#530725
Your switches and perch are backwards. From the end of the handlebar in it should go: grip, switches, perch.
Try and see if you can't swap them and end up with enough room for everything that way.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 21 Jun 2012 11:06 by StreetfighterKz.
  • Flyndrive
21 Jun 2012 11:19
#530727
Ha ha good call that's right they're backwards.
1980 KZ 550A1
1985 GPZ 900R
