Rear Master Cylinder Help
- Tulsa74136
17 Jun 2012 22:05 - 17 Jun 2012 22:05
The rear master cylinder on my 80 LTD 1000 needs to be rebuilt, the newest K & L catalog does not list a rebuild kit for my model. The main difference I see in the other kits in comparison to my master cylinder is the way the brake rod fits into the master cylinder. Anyone know of a source for a correct model rebuild kit.......or should I be looking for an earlier or later model year master cylinder replacement ???
Todd
Todd
1980 KZ1000 - B4 LTD (12/79 Mfd Date)
PODs, Kerker Header, Mikuni 29mm Smoothbores
Vetter Windjammer Fairing & Trunk
1981 KZ1000 - M1 CSR (03/81 Mfd Date)
All Stock except for PODs
1981 Yamaha XJ550H Maxim
All Stock
1977 KZ400 - D4 (2012/13 Winter Project) SOLD
All Stock
Last edit: 17 Jun 2012 22:05 by Tulsa74136.
Re: Rear Master Cylinder Help
17 Jun 2012 23:01 - 17 Jun 2012 23:10Tulsa74136 wrote: The rear master cylinder on my 80 LTD 1000 needs to be rebuilt, the newest K & L catalog does not list a rebuild kit for my model. The main difference I see in the other kits in comparison to my master cylinder is the way the brake rod fits into the master cylinder. Anyone know of a source for a correct model rebuild kit.......or should I be looking for an earlier or later model year master cylinder replacement ??? Todd
Would contact Z1 Enterprises about availability.
It's sometimes feasible to refurbish a m/c without any new parts.
Last edit: 17 Jun 2012 23:10 by Patton.
The following user(s) said Thank You: Tulsa74136
17 Jun 2012 23:09
Take a look at the bottom of the page in the link below. Redline says they offer new seals for your master cylinder piston.
redlinecycle.com/Brk%20-%20Mast.%20Cyl%20Piston%20-%20Rear.html
- wireman
17 Jun 2012 23:16
From what i remember the 80 is a one off sort of set up with remote resevoir ,I used that version on my z1 so it would work with my stock side covers
- clicker3499
17 Jun 2012 23:53
I just bought the rebuild kit for the rear master cylinder for my 81 KZ at Bike Bandit. I also found the rebuild kits for the calipers at this web site below
www.partsnmore.com/
www.partsnmore.com/
- Tulsa74136
18 Jun 2012 00:10
I guess I wasn't aware of Redline..........but wholly crap......$47.95 for the 2 cup seals, the cup seals listed above the 1980 listing were like $10 each.
All Stock
All Stock
18 Jun 2012 07:37
That is a pretty dear price for 2 little pieces of rubber - maybe they should change their name to bike bandit. But if they have them maybe someone else does too. You may want to call the folks at
www.cyclebrakes.com
They do not list the rebuild kit for your rear MC, but they may be able to provide some advice on the seals if you tell them about Redline offering them. Ed
- pete greek1
18 Jun 2012 16:40
good luck, finding them anywhere else, I must have called and looked up over a 100 places, with no luck at all, ended up buying a used master cylinder on e-bay, for $40.00 & got lucky & every thing was in working order,....1980 was the only year they had that style of master cylinder, so its slim pickins for parts...if i knew about redline I would have gladly paid that price
