is fluid level the same ?
  • pete greek1
  • pete greek1's Avatar Topic Author
17 Jun 2012 11:56
#529843
is the fluid level the same on all of the forks from 76-80 KZ 1000 ?
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: is fluid level the same ?
17 Jun 2012 12:16
#529848
180cc to 188cc on fully drained / empty fork. Use SAE 10W20
  • pete greek1
17 Jun 2012 12:23
#529849
10-4, I just wanted to make sure that the forks were all the same,for 76-80. ...thanks.
17 Jun 2012 14:00 - 17 Jun 2012 14:09
#529867
Factory specs for fork oil levels vary among different models.
For example --
Fork oil level per FSM measured from top of tube:
Z1 should be 455 mm, equal to approximately 17 15/16"
KZ900 @ 16.7"
1977 KZ1000 @ 426 mm
1978 KZ1000 @ 420 mm (16.5")
1979 KZ1000 @ 441 mm (17.4")
Would suggest being guided by the FSM as to each particular model.
FSM also provides refill volumes for both wet refills and dry refills.
Good Fortune! :)
Last edit: 17 Jun 2012 14:09 by Patton.
