Engine and frame identification!!!!
- old_skool_77
- Woot Woot
16 Jun 2012 23:46
Got an older Kz. Not exactly sure on the year or the frame or engine. The numbers on the frame and the casing is what I think is hand stamped, uneven numbers and letters. I looked at an 80 ltd that have and both frame and engine numbers are perfectly uniformed. Just was lookin to shed some light on my curiosity. I looked thru a few websites for the numbers but didn't find anything to show what I had. If anyone can tell me what I have or a website that might be able to help, I would greatly appreciate it.
The numbers on the frame are k1 019500 but the #1 that is before the nine is stamped backwards. And the number on the engine casing is k1e 019567. Another reason I believe they are hand stamped is the indentions aren't the same depth and some of the numbers and letters aren't trued, (flat and even thru out the stamp line). Was this common practice on kz's at one time? The frame also says made in Japan in the middle of the bar where the id marks are printed. Id marks on left side of bar if yer sittin on it. Any help is appreciated once again. Thanks
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
1976 kz 900
1977kz 1000
1980kz 1000 ltd
- 4TheKZ1000
- old_skool_77
- Woot Woot
Re: Engine and frame identification!!!!
17 Jun 2012 00:14
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
1976 kz 900
1977kz 1000
1980kz 1000 ltd
- 4TheKZ1000
17 Jun 2012 00:28
where the engine number is there should be a outer lip or raised casting lip that goes around the number sort of a border to the number, is this lip there or is it flat?
- 4TheKZ1000
17 Jun 2012 00:41
dont get caught on the street riding that hot mama! LOL
Attachment swat3.jpg not found
17 Jun 2012 00:53
Can you spot the previous owner?
Attachment 00000_2012-06-16-2.jpg not found
- 4TheKZ1000
- gd4now
- Denco where did you go?
17 Jun 2012 02:49 - 17 Jun 2012 02:51
Ed, they all look like the usual suspects to me - but I guess that is what usual suspects look like :dry:
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 17 Jun 2012 02:51 by gd4now.
- z1kzonly
17 Jun 2012 17:55
WTF? all re-stamps are not stolen! I dismantled 10 or so bikesa in the past 30 years.
just drag racing, dirt drag racing or selling for parts. All that was left was the title.
- 4TheKZ1000
17 Jun 2012 18:14 - 17 Jun 2012 18:17
it depends if the casting lip is gone or not....he hasent answered. Ive never seen a non factory stamping on a kz that wasent ground down a restamped due to being stolen.
Last edit: 17 Jun 2012 18:17 by 4TheKZ1000. Reason: add info
17 Jun 2012 18:43I don't understand a legal purpose for restamping a frame or engine. Maybe it's because there are different laws in different states? In MD the VIN stamped on the frame is used for registration of the bike, so your title and that frame should match. If you were to restamp a frame to a number different than that on your title it would no longer match the registration (not good). By the same token, if you were to steal a bike, grind off its number, and stamp in a number that matched your title, that would be illegal. The engine number never comes into play in MD. I had a 350cc single cylinder BSA model B40 into which I stuffed a 500cc twin BSA Cyclone engine, but the bike still was registered with the B40 frame number - no problem. Ed
- wireman
17 Jun 2012 18:46
I dont think factory replacement frames and engine cases came with numbers stamped in them,but are very few/far between.
Real early z1 cases didnt have raised rib on them.
