kz1000 streetfighter conversion w/zrx front & rear!
- 79MKII
- Love Them Kaws!
Re: kz1000 streetfighter conversion w/zrx front & rear!
31 Oct 2005 19:30
Awesome job! I have a '99 ZRX and often wonder how difficult it would be to convert the front and rear ends to my KZ. You make it sound so easy. I bid on a ZRX parts bike (no motor) a while back because I thought it would have made a geat donor bike for a KZ project. Yours looks excellent. More pics would be great!
The Kaw List:
- 1045
31 Oct 2005 20:27
Great looking bike!!! How does it handle now??
Whats up with the fork boots, is there a reason you put them on, or is it just for the look you wanted??
1045
1045
1045
- donthekawguy
31 Oct 2005 20:34
Now I have a plan for my bike!! Just need to get it running! :blink:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- azjax
01 Nov 2005 01:23
It handles great and the boots give the bike an even more aggresive look!
- galaxian
02 Nov 2005 14:19
Can you take a pic of the chain line? I woulld like to see your wheel from the back and how it lines up.
1977 KZ1000A1, 1979 KZ650 C3
- BohicaBob
02 Nov 2005 15:15
This might be of help. The following is from William H. Carpenter on a thread at dragbike.com/forum a few years ago:
"Important information for any wheel replacement. The chain line for a stock Z-1 bike is 3 5/8". This is the distance from the center of the wheel to the flange where the sprocket mounts. When this is combined with the now standard 5/8" offset (sprocket) gives a wheel with an offset of 4 1/4". This dimension is common for aftermarket wheels whether spoked or mags. If this dimension is something else, like using wheels from another bike, either the stock chain line is used and the wheel is not centered in the chassis or the chain line must be moved an equivalent amount to match the wheel. The wheel offset can easily be measured using a flat surface and a couple of straightedges (rulers). If the chain line is not maintained then the bike will easily break chains."
- z1rkrazy
02 Nov 2005 16:08
Awesome looking bike.....!!! Ride safe.....
- azjax
10 Nov 2005 01:35Please Log in or Create an account to join the conversation.
- Skully
10 Nov 2005 04:33
Sweeeeeet Azjax..........Very Nice !!!!
- azjax
12 Nov 2005 22:31
I've been asked how did I mount the kz gauges to the zrx triple tree? First I milled off all of the "stock" zrx stuff and then lathed two mounting points from round billet stock and welded the mounts onto the zrx triple tree. Check out the pics, you would think I paid for some expensive euro aftermarket part but it was just blood, sweat & tears!
Post edited by: azjax, at: 2005/11/13 01:38
- BohicaBob
- bob_z1
13 Nov 2005 09:17
Any idea how accurate your stock speedo is with that 17" front wheel? I was thinking of using the ZRX gages on mine....
