77kz1000ltd, missing part from rear axle? (pics)
- 74ullc
14 Jun 2012 15:22 - 14 Jun 2012 15:28
This is on my 1977 KZ1000LTD. PO had new tires put on it just before I bought it. It looks to me like something is installed wrong or left off the rear axle. I dont think its normal for the castle nut to be so deep on the axle that the cotter pin doesnt even touch it.
Also there is no mark on the chain adjuster to line up with the swing arm on the right side. Is that normal or could the chain adjuster be upside down???
It wouldnt surprise me if something is wrong here. Whoever put the wheels back on the bike after the new tires also messed up in the front. There was side to side play up front. Turns out they didnt have the speedo receiver gear engaged with the notches in the wheel hub. They left the axle nuts very loose, I'm guessing because when they tightened them up the wheel wouldnt spin because of the speedo gear problem. I got that all sorted out and now I want to make sure the rear is ok but I'm not sure what, if anything, is wrong.
Attachment 100_9321481x640.jpg not found
Attachment 100_9322481x640.jpg not found
Attachment 100_9323481x640.jpg not found
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
1977 KZ1000LTD
1984 VF700F
Last edit: 14 Jun 2012 15:28 by 74ullc.
- StreetfighterKz
Re: 77kz1000ltd, missing part from rear axle? (pics)
14 Jun 2012 15:39
From the parts diagram on Kawasaki.com, it appears that you're missing a washer that goes between the chain adjuster and the nut. (part #92022-248, WASHER,PLAIN,20MM)
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- 74ullc
14 Jun 2012 16:45StreetfighterKz wrote: From the parts diagram on Kawasaki.com, it appears that you're missing a washer that goes between the chain adjuster and the nut. (part #92022-248, WASHER,PLAIN,20MM)
Later, Doug
It looks like there is a washer there but maybe its part of the adjuster? There are little dimples on it that could be spot welds? You can see two of the dimples in the third pic, one is at the top of the castle nut, the other on the left side.
I just looked at the bottom of the chain adjuster, there is an alignment mark on the bottom, inside. So I'm betting the adjuster is upside down also.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
1977 KZ1000LTD
1984 VF700F
14 Jun 2012 17:10
Yes to missing flat washer
Yes to flip the adjuster
That should do it.
That should do it.
- 74ullc
14 Jun 2012 17:16 - 14 Jun 2012 17:17
So what looks like a washer is part of the adjuster....kinda figured that after looking at it closer.
The PO said the work (new tires) was done at a dealer. The more I learn the more I see that its by far best to get the real shop manual and do everything yourself.
My dad has a 1997 600 Eliminator, took it to the dealer for the valve check. Now its been back twice because the valve cover is leaking LOTS of oil. I told him to just get the gasket and lets do it ourself. Its just sad.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
1977 KZ1000LTD
1984 VF700F
Last edit: 14 Jun 2012 17:17 by 74ullc.
- wireman
14 Jun 2012 19:40
I dont trust the adjuster marks,I measure from center of swingarm pivot to center of axle bolt on each side to adjust.
Id say pull the rear wheel off and see what else is screwed up besides missing washer,not worth crashing and burning over.
- 74ullc
14 Jun 2012 19:51
I went to the local dealer to get the washer. While there a couple techs came out to look at it and they both think I'm also missing....
42032-081
COLLAR,REAR AXLE
They said it looks like the swingarm is pinched in too far. That part is obsolete so hopefully its not really missing.
Looks like I'll be pulling to check, going to change the bearings while in there too.
42032-081
COLLAR,REAR AXLE
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
1977 KZ1000LTD
1984 VF700F
- 74ullc
14 Jun 2012 19:53wireman wrote: I dont trust the adjuster marks,I measure from center of swingarm pivot to center of axle bolt on each side to adjust.
I'll be trying that trick for sure! Probably doesn't hurt to step back and eyeball it either.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
1977 KZ1000LTD
1984 VF700F
- wireman
14 Jun 2012 20:00Post a picture of what youve got once its apart74ullc wrote: I went to the local dealer to get the washer. While there a couple techs came out to look at it and they both think I'm also missing....
42032-081
COLLAR,REAR AXLE
- 74ullc
14 Jun 2012 20:06wireman wrote: Post a picture of what youve got once its apart
I will, the hardest part of the job is going to be getting the rear end off the ground safetly.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
1977 KZ1000LTD
1984 VF700F
15 Jun 2012 00:39 - 19 Jun 2012 09:0174ullc wrote:wireman wrote: Post a picture of what youve got once its apart
I will, the hardest part of the job is going to be getting the rear end off the ground safetly.Man I wish the LTD's had a center stand.
Lift the rear end (using a standard biker's pipe)
kzrider.com/forum/5-chassis/236039-center-stand
Parts diagram for wheel/axle assembly
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Last edit: 19 Jun 2012 09:01 by Patton.
- 74ullc
19 Jun 2012 05:30
Got it all apart and nothing is missing besides that washer. The collar that the mechanics at the kaw dealer thought was missing is in the brake caliper bracket.
The bearings feel good and have good fresh grease in them so I didnt change them.
The right side chain adjuster was upside down and I got that turned over so now I have a mark to go by. The rear wheel was crooked, and had the chain running in a bind. The tension on the chain (just over 1" up and down play) was correct. When I first got the rear wheel off the ground I could only spin the wheel 1/2 revolution before it would stop. Now that the wheel and chain are straight I can spin it 2 turns before it stops.
To get the rear wheel straight I went by the chain first. I got it to where its running straight when viewed from behind. Then checked the marks on the chain adjuster and then measured the distance from the center of swingarm pivot to the center of the axle bolt on each side. Everything looks spot on now, a test ride tomorrow will let me know if I got it right.
Before this the bike was wanting to lean/turn to the left. I didnt really notice it until I started to pay attention while riding over the weekend. I was pushing with my right hand to keep the bike straight without realizing it.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
1977 KZ1000LTD
1984 VF700F
