swing arm greasing
- hydrolazer
swing arm greasing
08 Jun 2006 07:45
how do you grease the swing arm? is there a grease fitting somewhere down there in never never land that i dont see????,,,tia
\'79 kaw 1000 ltd
- ejshotgun
Re: swing arm greasing
08 Jun 2006 08:04
On mine it's on top of the swing arm a little towards the front.
- hydrolazer
- wireman
08 Jun 2006 19:03
greasegun with flexible hose.you shouldnt have to grease it more than once a year.
- Pterosaur
08 Jun 2006 20:28
wireman wrote:
Ditto. YMMV, but the fitting on mine is dead center top of the swingarm and faces toward the right side of the bike. I have the stock battery box in mine and find it makes things mucho easier if I loosen the bolts holding the battery box down, then lift the box out of the way with a couple of paint stirring sticks taped together. Gives a much better angle to the head of the fitting, prevents that blob of icky spillage from growing on top of your swingarm...
- hydrolazer
09 Jun 2006 07:43
ok thanks i see it now with my flash lite and will break out my grease gun and give it a try today
\'79 kaw 1000 ltd
