Broken teeth on rear sproket
- XL777
11 Jun 2012 19:49
Well the money pit got me again! just finished doing another ton of maintenance and new parts only to fine my rear sprocket chain is toast.
Question if the teeth are broken was the chain out of alignment? Should I be getting a new chain and front sprocket?
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- Motor Head
Re: Broken teeth on rear sproket
11 Jun 2012 19:50
Yes replace the set, I would get an O-ring or X-ring chain.
11 Jun 2012 20:31
Replace both sprokets and chain as a new set.
Alignment may be fine, replace and align, and proper tension and lube..
What kind of driving do you do ? Sandy area ? Rusty ? Lack of care will kill these parts fast . Was rear sproket steel or aluminum ? Teeth will look like waves on the ocean when worn out bad and if not fixed the next step is broken off teeth. Go X or O ring chain for sure
11 Jun 2012 21:36
Also, use a new lock washer on the countersprocket nut. Ed
