KZ900 Aluminum swingarm doesn't quite fit
- Kapahulu
Re: KZ900 Aluminum swingarm doesn't quite fit
11 Jun 2012 18:29The top rails have not been cut off - there weren't any top rails. I'm not certain this is a Cal Fab swingarm. That's the only name that comes to mind though for an aluminum swingarm that fits a KZ900.4TheKZ1000 wrote: who cut off the rear top rails from the swingarm? The weld bead that is on the back top of swing arm used to host a upper stiffener bar. Yours are cut off?
2strokeworld.com
2strokeworld.com
- Kapahulu
18 Jun 2012 18:51 - 18 Jun 2012 18:52
Okay I got the swingarm on. It took some work to bend the brake rod to fit around the swingarm. And then I cut a piece of aluminum stock to make a shorter torque arm.
Went out riding today and the KZ handles nicely with the swingarm and wider back tire.
I've had this bike for nearly a year and only rode it a few miles until today. Got home and noticed some oil near the ignition cover. I hope the leak isn't coming from the crank seal!
2strokeworld.com
2strokeworld.com
Last edit: 18 Jun 2012 18:52 by Kapahulu.
- 4TheKZ1000
18 Jun 2012 20:13
that looks gr8, didnt know what it would look like with brackets cut off but /i like it. Well done!
- Kidkawie
- I bleed premix
19 Jun 2012 08:13
Be careful with an aluminum torque arm. I rippen one off on my Harley.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
19 Jun 2012 10:29
superfreakinnicebike man :evil: .
swingarm and wheel are very nice additions.
- Kapahulu
19 Jun 2012 14:41 - 19 Jun 2012 14:44
Thanks for the compliments! I used 1/8 thick aluminum for the brake arm, I think it will hold up. I hardly use the back brake anyways.
The broomstick drag bars look cool but I think I'm leaning too far forward while riding. Superbike bars may go on soon.
Checkout the license plate. Mad Max was already taken.
2strokeworld.com
2strokeworld.com
Last edit: 19 Jun 2012 14:44 by Kapahulu.
- Kidkawie
- I bleed premix
19 Jun 2012 15:19Kapahulu wrote: I used 1/8 thick aluminum for the brake arm, I think it will hold up. I hardly use the back brake anyways.
That's what I used, maybe a little thicker (but not 1/4"). Do what you want, but I BTDT.
1975 Z1 900
2004 KX125
2004 KX125
- les holt
19 Jun 2012 16:01
That's a good looking bike! Even the dog looks to be in a trance looking at it. :laugh:
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- kaw-a-holic
19 Jun 2012 17:29
What size tire did you get in there with that swingarm? How much did you have to offset the front sprocket?
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- Kapahulu
19 Jun 2012 21:20
I'm using a 130/90 x 18. No offset on the sprocket. The chain and sprockets are 530.
2strokeworld.com
2strokeworld.com
- kaw-a-holic
19 Jun 2012 21:24
Did you notice much difference? Is that the widest tire you could fit in that swingarm? Did you figure out who made it?
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
- zukdave
19 Jun 2012 22:15 - 19 Jun 2012 22:19
That arm looks about as wide as my gpz 750 arm.
With a disk brake and off set sprocket's
I can fit a 160-170 tire easy.
Mockup with a 130.
Mockup with a 130.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 19 Jun 2012 22:19 by zukdave.
