please any help on fork swap
  • ramtough_63
  • ramtough_63's Avatar
Re: please any help on fork swap
10 Jun 2012 23:43
#528073
my understanding is remove the weld from your existing steel botton press the stemm out. remove the stem from the new aluminum bottom (which is bigger around than your stem) machine a bushing to press into the aluminum triple that has the correct inside diameter to accept your steel stem. then weld it all up as I know nothing about welding steel and aluminum i would make sure whoever you have pressing and welding does. its a little more involved than finding some type of reducer ring.
hope this helps as les said leon has done this many times
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
