lube bearings
- Moshua
lube bearings
08 Jun 2012 22:15 - 08 Jun 2012 22:23
what kind of grease or Lube should i use to lubricate the ball bearings in my stem on the triple tree assembly. Its a 78 kz200
Last edit: 08 Jun 2012 22:23 by Moshua.
- Motor Head
Re: lube bearings
08 Jun 2012 22:18
As it is prone to get water around and in those, I would use a water proof grease. Brand and type probably not real important. Lube generously though, and be careful to get enough, but not to much pre-load. Are you replacing, and upgrading the bearings, so they have grease seals?
- Moshua
Re: lube bearings
08 Jun 2012 22:26
just putting my bike back together and i noticed that there is little to no grease in/on/around the steel ball bearings. factory specs did not have grease seals.
- Motor Head
Re: lube bearings
08 Jun 2012 22:34
You might want to look at some tapered roller bearings in a kit, that would have seals. All Balls is one supplier. Check z1enterprises.com to see if they list a kit, or go straight to allballs.com
But I find the re-sellers cheaper than allballs web site.
Re: lube bearings
08 Jun 2012 23:00Motor Head wrote: You might want to look at some tapered roller bearings in a kit, that would have seals. All Balls is one supplier. Check z1enterprises.com to see if they list a kit, or go straight to allballs.com
+1
Re: lube bearings
09 Jun 2012 00:22
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
Last edit: 22 Jan 2013 20:02 by martin_csr.
