Knock....knock....knock....knock
- faffi
06 Jun 2012 18:09
My KZ650 is making a not-always-perfectly rhytmic knock under acceleration, even very light acceleration. Hard acceleration doesn't seem to make it worse and may even reduce the knocking. I've heard it in all 5 gears, but it's most pronounced on the lower 2 gears - perhaps because there's no wind noise to muffle things.
The sound isn't constant in that it doesn't always appear and the intensity varies from time to time. There is no knock under deceleration.
At first I expected a stiff link in the chain because the knocks are too far separated to come from either sprocket. But there are no stiff links. Sprockets appear to be in decent condition, as is the chain.
Anybody experiences anything similar? Or have any idea what it could be other than the chain?
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
1980 F1 engine
B1 Points ignition
- redneckcarrow
Re: Knock....knock....knock....knock
06 Jun 2012 18:47
make shure the exhaust isn't hitting
1980 kz 550 ltd stock
- MFolks
06 Jun 2012 18:58
Checked the primary and cam chains for tightness?
06 Jun 2012 19:05
motor knocking from bad fuel or timing ????
- faffi
06 Jun 2012 19:07
Thank you both for the hints, but nothing hits the exhaust.
Why would a tight or slack cam- or primary chain give knocks with such long intervals and for what reason? If they can make this kind of sound I'd like to learn about it.
It doesn't sound like chain slop, it sounds more like a bad bearing or the chain being caught on a tooth or being forced to bend when it doesn't want to. Only all wheel bearings turn freely and smoothly and there is no slop on the wheel or swingarm.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
- faffi
06 Jun 2012 19:09Street Fighter LTD wrote: motor knocking from bad fuel or timing ????
No, it's not anything like pinging and that would be more rapid. It comes from the chain area - which could mean anything between output sprocket and rear wheel.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
06 Jun 2012 19:12
roll the bike fast, like down a small hill and listen with the motor turned off. see if you can eliminate motor or drive chain
- faffi
07 Jun 2012 03:30
I can try that sans helmet, but as mentioned there are no sound under trailing throttle.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
- faffi
07 Jun 2012 19:07
Well, after bending each link, cleaning and lubing the chain, the noise is gone
Not sure if it's the bending or the cleaning or the lube that did the trick, but things are quiet now.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
