ZRX1100 shocks on a Z1?
  • Kidkawie
  • Kidkawie's Avatar Topic Author
  • I bleed premix
03 Jun 2012 12:07
#526587
Besides the ZRX units being 3/4" longer, are they a direct swap? I cant find any info with someone using a stock swingarm. My back is killing me.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: ZRX1100 shocks on a Z1?
03 Jun 2012 16:44
#526615
Mounts need to be .800 wide top and bottom to fit,as measured on my ZRX.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Kidkawie
  • I bleed premix
04 Jun 2012 10:39
#526759
Looks like the width is the same as far as the mounts go. Any issues with chain clearance or the top mount/fender area?
1975 Z1 900
2004 KX125
  • wireman
  • wireman's Avatar
04 Jun 2012 10:57
#526763
carefull jacking up rear of bike too much,it does weird things to front end geomotry. B)
  • Kidkawie
  • I bleed premix
04 Jun 2012 10:59 - 04 Jun 2012 11:01
#526764
Thankfully, those shocks are serviceable. If the geo gets weird I can fab up some limiters to make them the right length. Just worried about side clearance as stated above.
EDIT: Already bought them, just want to see what I'm in for. :laugh:
1975 Z1 900
2004 KX125
Last edit: 04 Jun 2012 11:01 by Kidkawie.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
04 Jun 2012 23:06
#526947
just put em on and ride. then you'll know for sure. :)
i used a whole zrx12 rear end. if u jack the rear too high, u may have chain issues. the front should not be a problem, unless u plan on riding at very high speeds for extended periods. it will steer quicker.which is a good thing.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • etbike3135
  • etbike3135's Avatar
04 Jun 2012 23:48
#526969
They fit fine only problem is the chain guard. Either remove it or cut a big hole along side the shock.
1973 Kawasaki Z1
18 years in dragbikes
  • Kidkawie
  • I bleed premix
05 Jun 2012 09:22
#527022
Thanks for the info.
I'm tuning the bike so I can commute with it it during the week. About a 30 minute drive but I'm on the highway doing about 80-85, or at least trying to. haha Mark, I read your info on the shocks, but like yours I only found people using different swing arms.
I'll have to look into a used or aftermarket guard as mine is original to the bike and I really don't want to ruin it.
Will post pics when they show up.
1975 Z1 900
2004 KX125
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
05 Jun 2012 09:52
#527025
you need to keep your chain fairly tight or it will be slapping the top of the swing arm. You may need in install a guide for the chain if it hits too much.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • Kidkawie
  • I bleed premix
05 Jun 2012 10:08
#527027
Jeff.Saunders wrote: you need to keep your chain fairly tight or it will be slapping the top of the swing arm. You may need in install a guide for the chain if it hits too much.
That's only if I don't shorten the shocks, right?
1975 Z1 900
2004 KX125
  • steell
  • steell's Avatar
05 Jun 2012 15:03
#527065
I think if you shorten the shocks you'll end up regretting it and buying new ones anyway.
Shock has what, maybe 3" of travel? So shorten it one inch and you have two left, then subtract the sag and that leaves you with one inch of rear suspension travel.
Shorten the shock by one inch and you now have one inch of preload at the start.
I suggest buying the right length shocks.
  • Kidkawie
  • I bleed premix
05 Jun 2012 15:40 - 05 Jun 2012 15:42
#527070
I don't know exact measurements until I get them in my paws. But from what I've read they are approx 5/8-3/4" longer. Specs say ZRX stock travel is 4.6". I'll check the sag numbers compared to the shocks on there now before I fab anything. I've messed with some shocks before and there's some wiggle room you can use for additional travel by trimming the bump stop. When the shock is fully compressed, it doesn't mean the piston inside is all the way at the top. But like I said, I need them to measure.
Damping has got to be light years ahead of the crap on my bike now. I just might have to stiffen the stack a touch being the shock will already be partially in travel with the limiter.
1975 Z1 900
2004 KX125
Last edit: 05 Jun 2012 15:42 by Kidkawie.
