Tube tire on mag wheel?
- mike0537
02 Jun 2012 01:08
So I got a new rear tire with my bike. It is a tube tire. Can I use this on my mag wheel? The tire that is on it is tubeless....Thanx!
1980 KZ750E
Re: Tube tire on mag wheel?
02 Jun 2012 15:41
It would be helpful if you added the year/model of your motorcycle to your signature. Ed
02 Jun 2012 16:42
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
02 Jun 2012 17:05 - 02 Jun 2012 18:17A tire that requires a tube may be used with a tube on a rim that's designed for tubeless tires.mike0537 wrote: So I got a new rear tire with my bike. It is a tube tire. Can I use this on my mag wheel? The tire that is on it is tubeless....Thanx!
Generally, any tire may be run with a tube.
Whether a tubeless tire -- without a tube -- may be safely used, depends on the rim design.
A tube style rim design doesn't have the "ridges" found in a tubeless rim design.
Attachment tubevtubelessrimtxt.JPG not found
Some "mag" wheels on motorcycles are designed without the ridges, and are supposed to have tubes fitted with the tires. Examples include the genuine Morris Mags on KZ900-B1 LTD.
Some riders run tubeless tires without tubes on the "mag" wheels designed without the ridges that are supposed to have tubes fitted with the tires. Boo on them, imo, but they adamantly proclaim having nary a problem. Which imo is due to the smiling face of Lady Luck and never hitting a large bump while leaned over in a curve at speed -- as that's where the tubeless tire -- without a tube -- on a non-ridged rim may escape the non-raised rim, resulting in an instant "flat."
Last edit: 02 Jun 2012 18:17 by Patton.
- mike0537
02 Jun 2012 18:53
Thanx for the help Patton! BTW it is a 1980 KZ750 LTD. I added it to my signature for future use. Also I realized I should have gave some specifics after the fact.....
1980 KZ750E
