Anyone Try These Offset Sprockets?
  • NakedFun
  • NakedFun's Avatar Topic Author
30 May 2012 11:40
#525849
shop.pbisprockets.com/product.sc?productId=487&categoryId=56
Looks like a good price and they are supposedly made in the USA. May buy a 3/8 and 5/8 just for fitment check with the new swing arm.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Anyone Try These Offset Sprockets?
30 May 2012 11:46 - 30 May 2012 11:47
#525851
looks like a newcomer. never seen them before. great price. :)
i paid $95 for my 19 tooth 530 5/8"
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 30 May 2012 11:47 by mark1122.
  • NakedFun
30 May 2012 11:59
#525853
I think 5/8" you have to clearance the frame? That is why I was thinking of taking the 3/8" and milling the rear hub .200" to get it in line. I am running a ZRX1200 rear suspeion and wheel like you are.
Cory
1976 Kawasaki KZ900
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
30 May 2012 13:24
#525873
NakedFun wrote: I think 5/8" you have to clearance the frame? That is why I was thinking of taking the 3/8" and milling the rear hub .200" to get it in line. I am running a ZRX1200 rear suspeion and wheel like you are.
Cory
i heated the inner frame tube area and squeezed it flat on the inside to improve clearance. i also milled the hub to get it lined up.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • NakedFun
30 May 2012 13:26
#525875
So you had to use the 5/8" and mill the rear hub?
Cory
1976 Kawasaki KZ900
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
30 May 2012 13:37 - 30 May 2012 13:39
#525878
Yes , so i ended up with a 170 tire. but u could shim the rim instaed and run the rim off center and keep the 180 or larger tire.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 30 May 2012 13:39 by mark1122.
  • zed1015
  • zed1015's Avatar
30 May 2012 14:26
#525885
I run 5/8 offset and 180 tyre with 8mm machined off the rear sprocket carrier to align (ZX7 wheels).
With a 530 chain there is plenty of clearance and no chain fouling issues with either frame or tyre.
I also run the same setup on my Z1R but with a 630 chain and although everything is very close nothing actually touches.
Also with the 5/8 offset and over i would strongly recommend running an outrigger bearing.
  • porchev914
  • porchev914's Avatar
30 May 2012 14:38
#525888
mark1122 wrote: looks like a newcomer. never seen them before. great price. :)
Was that from D&G Mark? My offset sprocket was $165 for an 18 tooth 530. I wonder if it being a 1.24" offset had anything to do with the higher cost? Hmmmm.
FRANKEN Z!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
30 May 2012 14:45
#525891
yes that was d&g. if i recall correctly. the 630 15 5/8" offset i bought from them was $60.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • porchev914
30 May 2012 14:50
#525893
Thats what I thought. Oh well, I've got mine now. Another piece of the puzzle in place B)
FRANKEN Z!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
30 May 2012 14:56
#525896
dont u just love it when a puzzle comes together. :woohoo:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • NakedFun
30 May 2012 15:08
#525900
zed1015 wrote: I run 5/8 offset and 180 tyre with 8mm machined off the rear sprocket carrier to align (ZX7 wheels).
That is why I want to run the 3/8" sprocket up front to keep from having to run an outer support bearing for the output shaft. I know a guy on the ZRX forum (Chris) has a complete ZRX1100 (That ran the 170 tire) rear suspension on the MKII chassis and he used the 3/8" front with the .200" milled rear hub to have everything in alignment. I also know he milled equal .040" off each side of the swing arm pivot tube to get it to fit instead of milling a full .080" off one side.
Cory
1976 Kawasaki KZ900
