KZ1000 wheels
  • HDDAN
  • HDDAN's Avatar Topic Author
KZ1000 wheels
24 May 2012 09:54 - 24 May 2012 13:40
#524483
I have a 1982 KZ1000 CSR. I have a chance to buy a set of Lester wheels with drilled brake rotors. They are in really nice condition. Is there any cross reference chart any where that will tell me what fits what? I don't want to buy any wheels that are a major production to install. I do want to get rid of the laced wheels and tube type tires. The owner of the wheels told me that they are from a 1976-1980 KZ1000. Any help on whether these will fit on my CSR will be appreciated.
Last edit: 24 May 2012 13:40 by HDDAN. Reason: KZ100 instead of KZ1000
  • VenturaRider
  • VenturaRider's Avatar
Re: KZ1000 wheels
24 May 2012 16:49
#524554
Is the rear rim drum or disc brake? :whistle:
Box stock 75 Z1900
74 Z1900
Ventura Ca.
  • etbike3135
  • etbike3135's Avatar
Re: KZ1000 wheels
24 May 2012 19:28
#524584
The rear wheel with the disk brake is an easy swap. THe front wheel on your 81 has a differnt axle, spacers and brake rotor and maybe even the rotor spacing and diameter. Not saying its imposible but the front would not be bolt on.
1973 Kawasaki Z1
18 years in dragbikes
  • HDDAN
Re: KZ1000 wheels
25 May 2012 07:00
#524675
disc brake. So is my CSR.
  • HDDAN
Re: KZ1000 wheels
25 May 2012 07:02
#524676
etbike3135 wrote: The rear wheel with the disk brake is an easy swap. THe front wheel on your 81 has a differnt axle, spacers and brake rotor and maybe even the rotor spacing and diameter. Not saying its imposible but the front would not be bolt on.
Thank you for the information. If they are not a bolt on, I do not want them. I will get new stainless steel spokes and have the stockers re-laced.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: KZ1000 wheels
25 May 2012 07:29
#524677
If you can get these wheels cheap you might want to go ahead for resell or use them to barter. Roy
