clubman handle bar question...
  • joshjones84
  • joshjones84's Avatar Topic Author
23 May 2012 07:45
#524214
i was wondering what is the best way to put on clubman handle bars. do i have to shorten the clutch and throttle cable? if so how? how do i get the throttle off the old handle bars without braking them? do i get 7/8" or 1"? any advice would be GREAT!!!! thanks.
82 KZ550 LTD
  • Rainman
  • Rainman's Avatar
  • and a little Kaw shall lead them
Re: clubman handle bar question...
23 May 2012 14:58
#524275
Welcome joshjones84.
Assuming you have a KZ, the handle bar size is 7/8".
For throttle removal, remove left (clutch) side control, remove 4 headstock handle bar clamp screws, loosen the two screws holding the throttle housing and slide the throttle assembly off end of handle bars.
You can re-route the cables without the need to shorten, test for full front end steering,full right to full left to check for binding or pinch points.
This is a set mounted on a 80 KZ750 LTD
Good luck
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
  • joshjones84
23 May 2012 15:48
#524285
Awesome! thank you for the helpful info. I cant wait to get started. just another question. i found some bars on ebay and they look really nice. especially for $35! should i get the handlebars from a more reputable name or should these be fine?
82 KZ550 LTD
  • damarble
  • damarble's Avatar
23 May 2012 16:52
#524295
Just make sure to test everything before riding. When I first ditched the high rise bars my routing caused the engine to rev up at full right lock. You might see why that could be bad.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
  • Rainman
  • Rainman's Avatar
25 May 2012 01:45
#524640
josh, check Z1 Enterprizes, clubman bars black or chrome $26-$28 plus shipping would be my choice.
They have lots of other stuff you may need eventually and usually better prices than e-bay.
Good luck,
Jim
Jim
Quincy,IL
  • mtkawboy
  • mtkawboy's Avatar
25 May 2012 22:54
#524830
They look good but youll get tired of them real quick on long rides and the bike is kind of a hand full at slow speeds. I run the Superbike bars on mine, just a thought
  • ldizzle
  • ldizzle's Avatar
25 May 2012 23:02
#524835
I grabbed the pair off of ebay for $35 bucks- no big deal man! Great bars! You'll have to relocate your blinkers, but besides that, they're the stuff.
  • joshjones84
29 May 2012 06:29
#525594
just bought the black clubmans of Z1 Enterprises with grips and mirrors! ill take pics as soon as they come in. as far as getting tired of them real fast, i've had a Honda CBR600 F3 for two years. yes it makes your upper body sore but i got used to it within a couple of weeks. thanks for the replys guys!
82 KZ550 LTD
  • ZEARL
  • ZEARL's Avatar
07 Jun 2012 08:07
#527428
What have you guys done to relocate the turn signals? I just changed my bars, but the blinkers just barely fit (right hits tank when cranked all the way). Can I purchase something so I can mount them to the forks or just have something made up? I've got a '83 KZ550 Spectre.
  • kaw-a-holic
  • kaw-a-holic's Avatar
07 Jun 2012 08:26
#527430
Zeral
I put LED brinkers on mine. I drilled holes in the headlight bracket and mounted one on each side. If you use LEDs you will need the LED flasher as well. There is an LED topic in recent posts discussing the LEDs and the correct flasher. You can see mine in this pic.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • ZEARL
  • ZEARL's Avatar
07 Jun 2012 09:36
#527438
Thanks! I'll look into this.
  • gixxerkidd03
  • gixxerkidd03's Avatar
11 Jun 2012 02:08
#528100
just a question. you dont need to get the "WIDE" clubman bars if im running them on a 82 kz750 ltd do I?
1981 KZ750e
