Are these mounts bent??
- moneypit
21 May 2012 21:03 - 21 May 2012 21:09
After my unintended wheely I noticed that the mounts didnt look right. Havent riden since due to the stator cover. If they are what else should I look for. By the way these are the rear mounts.
[attachment:1]C:\fakepath\motor mounts 009.JPG[/attachment]
Attachment motormounts010.JPG not found
Attachment motormounts012.JPG not found
Attachment motormounts003.JPG not found
Attachment motormounts004.JPG not found
Attachment motormounts006.JPG not found
Attachment motormounts008.JPG not found
2-76 kz900
St Paul MN
St Paul MN
Last edit: 21 May 2012 21:09 by moneypit.
- baldy110
- moneypit
Re: Are these mounts bent??
22 May 2012 17:15
Anything else I should be on the lookout for regarding the other mounts or frame
2-76 kz900
St Paul MN
St Paul MN
- wireman
22 May 2012 18:01
How hard did you hit?
Ive done cart wheels before that didnt bend motor mounts,now the forks were a differant story! :sick: :woohoo:
- etbike3135
22 May 2012 19:18
Look for cracks in the engine cases, especially by the 2 lower bolts in the middle (the big bolts with the 17mm head).
1973 Kawasaki Z1
18 years in dragbikes
- moneypit
23 May 2012 22:23 - 23 May 2012 22:27wireman wrote: How hard did you hit?
Bike went straight up, back rest sticking out of the luggage rack was my wheely bar for ten feet,it came down side ways on the left cover (see pic). Didnt slide at all. Only other damage so far is the lower left pipe is alittle flat(stock pipes) Only oil that leaked was from the stator cover.
I will look at all the mounts as I get time, motor is still in, I want to make sure its straight or NO ride in the relay. Also looking for a stator cover(anyone?)
2-76 kz900
St Paul MN
St Paul MN
Last edit: 23 May 2012 22:27 by moneypit.
- munkybrain2010
- Clueless..
24 May 2012 17:02
holy crap sounds like a rough ride! :S
trying to race those turbo busas off the starting line??
Keep it together man!
79 KZ650 "Geto Cycle"
