Can Front Wheel Install Either Way KZ750?
  • rustbuckett
  • rustbuckett's Avatar Topic Author
20 May 2012 15:19 - 20 May 2012 15:20
#523567
'82 KZ750, bought used a couple weeks ago. Just noticed the front tire is mounted backwards (forward arrow points to the rear).
Question: can I simply remove the front wheel, dis brake rotors and all; and just swap it around 180 degrees sideways and bolt it right back on so the tire spins forward?
Or will the wheel only go on in one orientation.... making me have to take the wheel to a shop and have them un-mount the tire and re-mount it the right way...
A couple snapshots of the wheel, one from left side, the other from the right.
Thanks for any smarts.
[attachment:1]HPIM1720.JPG[/attachment]
[attachment:2]HPIM1719.JPG[/attachment]
82 KZ750-N1 Spectre (reviving)
88 EN450-A4L (reviving)
81 Suzuki GS450 (project)
Five Yamaha Blasters YFS200 (for the kids)
01 TT-R 125 (for youngest boy)
96 Honda Foreman 400 4X4 Old Faithful workhorse
Last edit: 20 May 2012 15:20 by rustbuckett. Reason: spelling error
  • bountyhunter
  • bountyhunter's Avatar
Re: Can Front Wheel Install Either Way KZ750?
20 May 2012 15:30
#523569
Can't read the pictures. The tire may be correct as is: If the tire is intended for a "rear fitment", you do reverse it's direction if you mount it on the front. The Avons I used to run had two atrrows on the sidewall, one labeled "front fitment" and the reverse arrow labeled "rear fitment". Find out if it's designed to be a rear tire, if it is the arrow should be reversed if used on the front.
  • bountyhunter
20 May 2012 15:32
#523570
That would not work on mine. Does yours have the speedo drive on the left side?
  • wireman
  • wireman's Avatar
20 May 2012 17:13
#523583
Put speedo drive on other side. B)
  • steell
  • steell's Avatar
20 May 2012 19:17
#523614
wireman wrote: Put speedo drive on other side. B)
That would make the speedo cable turn backwards.
  • rustbuckett
20 May 2012 20:00
#523621
Well I think I'm screwed. Yes, left side of front wheel has the speedometer cable assembly. And the tire says "FRONT USE ONLY" but the arrow points to the rear. The guy mounted the tire backwards.
I don't know why the photos didn't upload.... I'll try one more time, just the left front side.
Attachment HPIM1718.JPG not found
  • wireman
  • wireman's Avatar
20 May 2012 23:15
#523689
not if the wheel is spun around it will be on the left side of wheel B)
  • steell
  • steell's Avatar
21 May 2012 00:41 - 21 May 2012 00:45
#523722
Can you swap the speedo drive tang from one side of the wheel to the other?
Last edit: 21 May 2012 00:45 by steell.
  • wireman
  • wireman's Avatar
21 May 2012 00:48
#523725
Take the parts for the speedo drive that stick through hub that the housing attaches to and put them out the oppisite side of hub,then flip the wheel around so that side is on the left and reattach the speedo and wheel just like origional,the rim/wheel doesnt care which way its installed on the bike.
then your tire will be facing right direction ,speedo will operate correctly B)
  • wireman
  • wireman's Avatar
21 May 2012 00:48
#523727
steell wrote: Can you swap the speedo drive tang from one side of the wheel to the other?
Yes its all interchangable :)
