Fork seal replacement on KZ1000 A2
  • KZ1000inaus
  • KZ1000inaus's Avatar Topic Author
  • Luminous Red KZ1000 A2
14 May 2012 01:02
#522204
Ive just noticed oil deposits around my fork seal area.
How difficult a job is it to replace them and when i do what sort of oil (and amount) do you recommend?
  • wireman
  • wireman's Avatar
Re: Fork seal replacement on KZ1000 A2
14 May 2012 01:18
#522206
It snot that big of a deal if you have a manual,I like synthetic motor oil in the 30w range myself B)
  • 0Z.Z1R Mk2
  • 0Z.Z1R Mk2's Avatar
14 May 2012 01:45
#522210
This will give you a bit of an idea....cant help with amount of oil required. ;)
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
The following user(s) said Thank You: TomasDouglas
  • steell
  • steell's Avatar
14 May 2012 02:14
#522215
You might get a really thin feeler gage and run it around the inside of the fork seals between the fork leg and the seal.
Quite often solves the problem.
