help with 1982 kz1100 rake and trail
  • beachbumtroy
  • beachbumtroy's Avatar Topic Author
13 May 2012 17:31
#522099
im having no luck everywhere ive tried so wanted to ask u guys if u can give me the answer or lead me to where it would be? i just got a 1982 kz 1100 and am using it on a trike project and was wanting to know if anyone can tell me the o.e.m rake and trail it was suppose to have? any help or leads r greatly appreciated thnx bb
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: help with 1982 kz1100 rake and trail
13 May 2012 18:35 - 13 May 2012 18:39
#522110
do u have the complete bike? if so , we can help u measure it.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 13 May 2012 18:39 by mark1122.
  • beachbumtroy
13 May 2012 19:36
#522122
no guys sorry i just have the front end,i know i can put it practically anywhere i want just was hoping to get the original rake and trail to try and keep it close to what it was from factory,so if u know that i would appreciate it thnx bb
  • damarble
  • damarble's Avatar
13 May 2012 19:43
#522124
Would the original rake and trail even be ideal for a trike?
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
  • beachbumtroy
13 May 2012 19:53
#522125
i honestly dont know this is my first trike project and im new to this,where i have it mocked up is about 30 degrees but as i said i can put it where ever im just having no luck getting the original specs,more of a curiousity thing than anything.so appreciate the responses just hoping for the o.e.m specs thnx bb
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
14 May 2012 19:11 - 14 May 2012 19:12
#522354
the rake wont change unless u raise or lower either end of the bike, or bend the neck. if u raise the ass,1 inch the rake will decrees about 1*. the stock rake for a kz is about 26* . modern sport bikes r at 23/24* 30 is pretty low. this will make it turn in very easily but may be unstable at high speed.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 14 May 2012 19:12 by mark1122.
  • beachbumtroy
14 May 2012 19:17
#522360
ok appreciate the info thats what i wanted to know was the stock rate for the rake and u say it was about 26 degrees then thats awful close to where it is mocked up so i guess i`ll be alright thnx bb
  • damarble
  • damarble's Avatar
14 May 2012 20:49
#522389
I found specs for the KZ1000P at 27 degrees with 4.5" trail, that should keep you close. Make sure you have enough trail, that will lend high speed stability.
  • beachbumtroy
14 May 2012 23:15
#522420
ok guy thnx ill make sure i get my trsail right also thnx for all the input.
