Killing the handlebar buzz?
  • les holt
  • les holt's Avatar Topic Author
  • Vendor
  • Vendor
13 May 2012 09:31
#522003
I've got a wicked handlebar vibration at around 3000-3500 that makes my hand numb right now, looking for some different ideas to isolate it.
Les
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Killing the handlebar buzz?
13 May 2012 09:43
#522005
After the first build ~ 1000 miles, I found my hands started going numb... Couldn't figure it out at first and it seemed to get worst each ride...
Believe it or not, turned out my rear exhaust support clamp to frame bolt came loose. Damn thing oscillated (frequency) and sent it through the frame... :blink: I was like you have to be kidding me but sure enough...
In a talk with Larry, mentioned he's witnessed that himself where with these engines power/torque, frame mounting bolt come loose, suspension mounts, foot peg mount etc... yup will travel to the bars.
I also tied the bar snake hard foam insert, helped a tad but naw... Biggest help turned out the weighted handle bar ends (mine weighted bar mirrors).
Good luck on finding the problem Les,
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
13 May 2012 09:49
#522006
What OMR said and I went to foam grips instead of hard rubber grips
13 May 2012 09:53
#522007
Be sure to double check all the engine mount bolts to make sure none are a little loose. Ed
  • Medina
  • Medina's Avatar
13 May 2012 10:04
#522012
650ed wrote: Be sure to double check all the engine mount bolts to make sure none are a little loose. Ed
you gave me that suggestion a year ago or so.
Snugging them up with a torque wrench finally was the ticket, just tightening them helped, wasn't until I torqued them its now (combined with oversize soft rubber grips) is all but gone
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
  • les holt
  • Vendor
  • Vendor
13 May 2012 10:05
#522014
I've done multiple re torques of all the engine bolts and all the critical components and give a good visual shakedown of everything else but that's not to say I've overlooked something so I'll address that this evening. I thought about the weights in the end of the handle bars and may just go ahead and add them for added comfort but the foam grips just never did last long, they seemed to deteriorate pretty quickly. I also thought about putting a thin piece of rubber under the handlebar mounts.
Thanks for your input guys! I need to cure this before the relay.
Les
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
13 May 2012 10:34
#522020
i dont seem to have a buzz like that, but i do get a blurry right side mirror. i have ruber mounts under the bar rizers. stiill there with new mirrors. i may try wieghts.
some of the modern bikes have bar wieghts, so u may find some cheap on ebay. my 01 cbr600f4i has them, and my pals Honda 919, uses the same ones.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Old Man Rock
13 May 2012 10:43 - 13 May 2012 10:44
#522026
If not going with mirrored ends.... They make user adjustable weighted bar ends as well and could be accomplished on the fly...
Now that would be the ticket to success... ;)
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 13 May 2012 10:44 by Old Man Rock.
13 May 2012 11:30
#522040
If the buzz won't go away I wonder if you could load the inside of the end of the handle bars with lead shot (maybe in small plastic bags) like they use in dead-blow hammers to dampen the vibration? Ed
  • Old Man Rock
13 May 2012 11:37
#522042
Virginia back woods method (Larry) Fill with concrete.... :blink:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Kawickrice
  • Kawickrice's Avatar
13 May 2012 12:31
#522053
The MX guys use silicone caulk in thier MX bars to try to combat this. I like tacky grips so I have the buzz too, I use riding gloves with the fingers cut off and padding on the palm
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Zedone
  • Zedone's Avatar
13 May 2012 20:07
#522129
What type of bars are they Les? Superbike?
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
