Help ID Brake Part '76 KZ900
  • pig9r
  • pig9r's Avatar Topic Author
10 May 2012 09:13
#521194
I am in the process of putting my '76 KZ900 back together. I came across this spring in my master cylinder and front caliper hardware. I was good about taking pics of everything, but of course I don't have a pic for it and I haven't spotted it in the parts manual.
Any expert help would be greatly appreciated. Thanks!
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
Re: Help ID Brake Part '76 KZ900
10 May 2012 09:49
#521201
Not from the M/C. Maybe a carb air screw mixture spring?
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • Kawickrice
  • Kawickrice's Avatar
10 May 2012 10:02
#521202
It looks to be the spring in the master cylinder that pushes the piston back
Kawasaki.com will have an exploded view and it will make since when you see the diagram
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
10 May 2012 10:22
#521206
Kawickrice, wouldn't the M/C spring be longer than 10mm. And it would be tapered to one end kinda cone like without the point. I just rebuilt my M/C about a month ago. Don't remember a spring that looks like that. Here's what mine looked like. Master Cylinder Kit
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • wireman
  • wireman's Avatar
10 May 2012 21:05
#521333
on the trapezoid front master cylinder its between 36-40mm,not sure about the older round style
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
10 May 2012 21:23
#521338
On the "older round style" (i.e. 1/2" bore, single front caliper), the spring is at least an inch and a half long. I JUST rebuilt mind last week, otherwise I'd measure it for you.
That spring doesn't look to be from the caliper either, as I rebuilt mine last week too.
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • pig9r
10 May 2012 22:14
#521356
It is not the spring that goes on the plunger in the master cylinder. My initial thought when I saw it in the bag was that it went in the front brake handle assembly. I just can't remember and it doesn't show in any of the pics I took during disassembly.
  • Kawboy74
  • Kawboy74's Avatar
10 May 2012 22:32
#521364
I will go out on a limb here and say it is the spring that goes into the kick start lever where it has a detent built into the boss for a little ball and that spring. Your kick start lever should click when it turns out for use and that spring and ball holds it fully open and fully closed.All of this is exposed when you pull the cir-clip and washer off to chrome the parts or do a cleanup.
Curious to know!
David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
  • pig9r
11 May 2012 10:00 - 11 May 2012 10:03
#521511
Kawboy74, I think you are right. Thanks!
I did take it apart to have the lever rechromed and haven't reassembled it yet. And I had the washer and circlip zinc plated. Thanks everyone for their help. I would have spent a while trying to figure that one out.
Last edit: 11 May 2012 10:03 by pig9r.
  • Kawboy74
  • Kawboy74's Avatar
11 May 2012 10:20
#521512
You're welcome! Every once in a while the old noodle does work!
Good luck.
David
