Extending the life of a cracked cable shield
  • damarble
  • damarble's Avatar Topic Author
09 May 2012 17:07
#521037
I picked up a new (used) tach cable and the housing/shield is cracked in one spot and the metal core looks to be separating a little. Don't have money for another at this time so considering a repair. Was thinking of sleeving that section with a spring and slipping heat shrink over the thing. Better ideas?
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Extending the life of a cracked cable shield
09 May 2012 17:33
#521045
maybe heat shrink,then the spring,then some more heat shrink.
that way the first layer will keep the water out.
  • wireman
  • wireman's Avatar
09 May 2012 19:21
#521065
3m brand super33 electrical tape is da bomb B)
09 May 2012 21:06 - 09 May 2012 21:07
#521087
For later consideration --
www.z1enterprises.com/detail.aspx?ID=3994
Good Fortune! :)
Last edit: 09 May 2012 21:07 by Patton.
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
09 May 2012 22:07 - 09 May 2012 22:08
#521107
Might try repairing it with epoxy first, then cover it with a sheathing. HF sells two part epoxy for under two bucks. Can't tell you how many rubber pieces I repaired (MC bango bolt cover, instrument bulb rubber pieces, carb grommets and foot peg grommets, etc). It wasn't cost since all those things are cheap, but didn't want to have to wait for an order each time I tore something.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 09 May 2012 22:08 by KZJOE900.
  • damarble
09 May 2012 23:37
#521133
Patton wrote: For later consideration --
Good Fortune! :)
For $16 I'll wrap it in tape and run it till it breaks. Used ones are going for more than that on ebay....
Good suggestions for fixes away from home though.
